See "Attention (Installing the Laser MFP Drivers and MF Toolbox)." in advance.
When you are in an IPv6 environment, you may not be able to use the installation procedure below to install the Laser MFP Drivers.
See "Installing the Laser MFP Drivers on the WSD Network" to install the Laser MFP Drivers.
Note that you cannot use the scan functions in an IPv6 environment.
To use Printer Driver other than UFRII through the USB connectionYou need to change the machine setting beforehand. Choose the PDL (Printer Driver) that you want to use and follow the procedures shown below.
] (Menu) -> <System Settings> -> <Select PDL (Plug-n-Play)> -> <USB> -> Select the PDL (Printer Driver) that you want to use
When this dialog box does not appear |
When the language selection screen is displayed before the CD-ROM setup screen appears Select the language and click [Next].
Windows Server 2003/Server 2008
This screen is not displayed. Proceed to the following procedure.
(1)
Select the device.
(2)
Click [Next].
When no devices are displayed in [Device List]Try the following procedure.
If the problem persists, try the following procedure.
If any devices are not displayed by performing the above procedure, click [Display Guide] to solve the problem.
For USB Connection
For Network Connection
Continue with the steps in the procedure below to start installation of the MF Toolbox.
] under [Install] and click [Next].
(1)
Select the [Restart Computer Now (Recommended)] check box.
(2)
Click [Restart].
The CD-ROM can be ejected once this screen appears.
To connect the machine using a USB cable, wait until your computer is restarted.
To connect the machine to the network, check the installation results.
When the above dialog box does not appear |
When the language selection screen is displayed before the CD-ROM setup screen appearsSelect the language and click [Next].
(1)
Select the machine.
(2)
Click [Next].
If any devices are not displayed by performing the above procedure, click [Network connection guide] to solve the problem.
(1)
Select the driver that you want to install.
(2)
Click [Next].
[Printer]
Install to use the print functions.
[Fax (for Supported Models)]
Install to use the fax functions on your computer. (Once you have the driver installed on your computer, you can send your document or image files to a fax-enabled device directly from your computer.)
[Scanner]
Install to use the scan functions.
[UFRII LT Printer Driver]
Install to use the UFRII LT Printer Driver functions.
[PCL5e Printer Driver]
Install to use the PCL5e Printer Driver functions.
[PCL6 Printer Driver]
Install to use the PCL6 Printer Driver functions.
[PS 3 Printer Driver]
Install to use the PS 3 Printer Driver functions.
(1)
Enter the correct information.
(2)
Click [Next].
Printer information(UFRII LT)*1
Printer information(PCL5e)*2
Printer information(PCL6)*3
Printer information(PS 3)*4
Fax information*5
*1
Appears when [UFRII LT Printer Driver] is selected in Step 8.
*2
Appears when [PCL5e Printer Driver] is selected in Step 8.
*3
Appears when [PCL6 Printer Driver] is selected in Step 8.
*4
Appears when [PS 3 Printer Driver] is selected in Step 8.
*5
Appears when [Fax (for Supported Models)] is selected in Step 8.
[Printer Name]
Enter a different name to change the default name.
[Fax Name]
[Use as Shared Printer]
Select the check box to set the printer or fax as a shared printer or fax.
[Use as Shared Fax]
[Shared Name]
Specify the shared name.
When the [Use as Shared Printer] or [Use as Shared Fax] check box is selected
Follow the steps in the procedure below to install the additionally required driver.
(1)
Select the printer that you use most often.
(2)
Click [Next].
This screen appears only when installing the printer driver and fax driver.
(1)
Select the check box to print a test page.
(2)
Click [Next].
This screen appears only when installing the printer driver.
For USB Connection
The applications of which check boxes were selected in Step 4 will be installed.
Follow the onscreen instructions. |
(1)
(2)
Click [Restart].
Flat end (A):
Connect (A) to the USB port on the computer.
Square end (B):
Connect (B) to the USB port on the machine.
When a dialog box is displayedFollow the onscreen instructions and complete installation.
When installation is complete, check the installation results.
Software
Location
Icon
Printer driver
[Devices and Printers] folder
Fax driver
Scanner driver
[Scanners and Cameras] or [Scanners and Cameras Properties] folder
For network connection
For USB connection
MF Toolbox
Desktop
Network Scan Utility
Taskbar
