How to Open the Printer Folder
Windows XP Professional, and Server 2003
From the [Start] menu, select [Printers and Faxes].
Windows XP Home Edition
From the [Start] menu, select [Control Panel], click [Printers and Other Hardware] and [Printers and Faxes].
Windows Vista
From the [Start] menu, select [Control Panel] and click [Printer].
Windows 7, and Server 2008 R2
From the [Start] menu, select [Devices and Printers].
Windows Server 2008
From the [Start] menu, select [Control Panel], and then double-click [Printers].
How to Display the [Scanners and Cameras] or [Scanners and Cameras Properties] Screen
Windows XP
From the [Start] menu, select [Control Panel] and click [Printers and Other Hardware] -> [Scanners and Cameras].
Windows Vista
From the [Start] menu, select [Control Panel] and click [Hardware and Sound] -> [Scanners and Cameras].
Windows 7
Enter "scanner" in [Search programs and files] under the [Start] menu.
Click [View scanners and cameras].
How to Display [Windows Fax & Scan] Screen
Windows Vista
From the [Start] menu, select [Control Panel] -> [Hardware and Sound] -> [Scan a document or picture] in [Scanners and Cameras].
Windows 7
From the [Start] menu, select [All Programs] -> [Windows Fax and Scan].
How to Display the Top Screen of CD-ROM
If you cannot display the top screen when setting CD-ROM, perform the following operations.
The CD-ROM drive name is indicated as "D:" in this manual. The CD-ROM drive name may differ depending on the computer you are using.
Windows XP, and Server 2003
From the [Start] menu, select [Run].
Enter "D:\Minst.exe", and then click [OK].
Windows Vista, 7, and Server 2008
Enter "D:\Minst.exe" in [Search programs and files] (or [Start Search]) under the [Start] menu.
Press the [ENTER] key on the keyboard.
How to Check the Windows Vista/7/Server 2008 Processor Version
1
Select [Control Panel] from the [Start] menu.
2
Display [System].
Windows Vista/Windows 7/Windows Server 2008 R2
Click [System and Maintenance] or [System and Security] -> [System].
Windows Server 2008
Click [System].
3
Check the Processor Version.
For 32-bit versions
[32-bit Operating System] is displayed.
For 64-bit versions
[64-bit Operating System] is displayed.
