] (Menu) -> <Fax Settings> -> <Fax Setup Guide>
] or [
] and press [OK].
The receive mode is set to <Auto>.
Press [OK] and connect the machine with the telephone line.
Receive faxes automatically.
The telephone functions do not be used.*
When the telephone is connected in the auto receive mode, the telephone rings when receiving a fax or telephone call. You can answer the telephone while it is ringing.
To turn off the telephone ringer, see "Incoming Ring."
] or [
] and press [OK].
The receive mode is set to <Fax/Tel Auto Switch>.
Receive faxes automatically.*
Respond to a telephone call by picking up the handset.
The telephone rings on incoming calls. To turn off the telephone ringer, see "Incoming Ring."
] or [
] and press [OK].
The receive mode is set to <Answering Machine>.
Press [OK] twice and connect the machine with the telephone line.
Respond to telephone calls using the built-in answer function.
Ring on incoming calls or faxes.
The receive mode is set to <Manual>.
Respond to incoming calls or faxes by picking up the handset.
