Drawer 1
In case of portrait orientation (only when the UFR II printer driver is used): Short edges 5.83 to 8.50 in. (148.0 to 215.9 mm); Long edges 5.83 to 8.50 in. (148.0 to 215.9 mm)
In case of landscape orientation: Short edges 4.00 to 8.50 in. (101.6 to 215.9 mm) *1; Long edges 5.83 to 11.69 in. (148.0 to 297.0 mm) *2
Drawer 2 (optional)
In case of portrait orientation (only when the UFR II printer driver is used): Short edges 8.27 to 8.50 in. (210.0 to 215.9 mm); Long edges 8.27 to 8.50 in. (210.0 to 215.9 mm)
In case of landscape orientation: Short edges 5.83 to 8.50 in. (148.0 to 215.9 mm); Long edges 8.27 to 14.00 in. (210.0 to 355.6 mm)
Multi-purpose tray
In case of portrait orientation (only when the UFR II printer driver is used): Short edges 5.00 to 8.50 in. (127.0 to 215.9 mm); Long edges 5.00 to 8.50 in. (127.0 to 215.9 mm)
In case of landscape orientation: Short edges 3.00 to 8.50 in. (76.2 to 215.9 mm); Long edges 5.00 to 14.00 in. (127.0 to 355.6 mm)
*1
When width is 8.50 in. (215.9 mm), max length is 11.00 in. (279.4 mm).
*2
When length is 11.69 in. (297.0 mm), max width is 8.27 in. (210.0 mm).
: Available|
Paper Type
Drawer 1
Drawer 2 (optional)
Multi-purpose Tray
Plain paper (16.0 to 27.9 lb Bond (60 to 105 g/m²))
Heavy paper (26.6 lb Bond to 60.3 lb Cover (100 to 163 g/m²))
Heavy paper (60.6 to 79.9 lb Cover (164 to 216 g/m²))
60.6 to 65.1 lb Cover (164 to 176 g/m²) heavy paper can be loaded.
The print speed drops when printing on heavy paper (26.6 lb Bond to 79.9 lb Cover (100 to 216 g/m²)).
