Heavy paper of 65.2 to 79.9 lb Cover (177 to 216 g/m²) can only be loaded in the Multi-purpose tray.|
Drawer 1
Drawer 2 (optional)
Multi-purpose Tray
Standard sizes
A4*1, B5*1, A5*1, A6*2, Letter*1, Executive*1, Statement*2 and 16K*1
A4*1, B5*1, A5*1*2, Legal*1, Letter*1, Executive*1, Foolscap*1 and 16K*1
A4*1, B5*1, A5*1, A6*2, Legal*1, Letter*1, Executive*1, Statement, Foolscap*1, 16K*1 and Index Card
Custom paper sizes
In case of portrait orientation (only when the UFR II printer driver is used): *3
Short edges 5.83 to 8.50 in. (148.0 to 215.9 mm)
Long edges 5.83 to 8.50 in. (148.0 to 215.9 mm)
In case of landscape orientation: *3
Short edges 4.00 to 8.50 in. (101.6 to 215.9 mm) *5
Long edges 5.83 to 11.69 in. (148.0 to 297.0 mm) *6
In case of portrait orientation (only when the UFR II printer driver is used): *4
Short edges 8.27 to 8.50 in. (210.0 to 215.9 mm)
Long edges 8.27 to 8.50 in. (210.0 to 215.9 mm)
In case of landscape orientation: *4
Long edges 8.27 to 14.00 in. (210.0 to 355.6 mm)
Short edges 5.00 to 8.50 in. (127.0 to 215.9 mm)
Long edges 5.00 to 8.50 in. (127.0 to 215.9 mm)
Short edges 3.00 to 8.50 in. (76.2 to 215.9 mm)
Long edges 5.00 to 14.00 in. (127.0 to 355.6 mm)
*1
Can be used for 2-sided printing. (60.6 to 79.9 lb Cover (164 to 216 g/m²)) heavy paper cannot be used for 2-sided printing.)
*2
The paper can be loaded only in landscape orientation (when the long edges of the paper are parallel to the front side of the printer).
*3
Automatic 2-sided printing can be performed on the custom size paper whose short edges are 5.83 to 8.50 in. (148.0 to 215.9 mm) and long edges are 8.27 to 11.69 in. (210.0 to 297.0 mm).
*4
Automatic 2-sided printing can be performed on the custom size paper whose short edges are 5.83 to 8.50 in. (148.0 to 215.9 mm) and long edges are 8.27 to 14.00 in. (210.0 to 355.6 mm).
*5
When width is 8.50 in. (215.9 mm), max length is 11.00 in. (279.4 mm).
*6
When length is 11.69 in. (297.0 mm), max width is 8.27 in. (210.0 mm).
Recycled paper can be also used.
When using custom size paper
: Available
: Unavailable|
Paper Type
Drawer 1
Drawer 2 (optional)
Multi-purpose Tray
Plain paper (16.0 to 27.9 lb Bond (60 to 105 g/m²))
Heavy paper (26.6 lb Bond to 60.3 lb Cover (100 to 163 g/m²))
Heavy paper (60.6 to 79.9 lb Cover (164 to 216 g/m²))
Index Card
60.6 to 65.1 lb Cover (164 to 176 g/m²) heavy paper can be loaded.
The following Index Card size is supported.
3.00 x 5.00 in. (76.2 x 127.0 mm)
The print speed drops when printing on heavy paper (26.6 lb Bond to 79.9 lb Cover (100 to 216 g/m²)).
The print speed drops when printing on rough paper (19.9 to 23.9 lb Bond (75 to 90 g/m²)).
