» Useful Printing Functions » Printing without the Printer Driver (Direct Print) » Direct Printing from Command Prompt
The command of the following format is effective.
lpr (a space) -S (a space) <the IP address of the printer> (a space) -P (a space) <the printer name> (a space) <the file name>
The printer name
Enter the printer name. You can check the printer name in [Device Name] on the remote UI portal page.
The file name
Enter the name of the file to be printed.
Input Example
<If the IP address of the printer is "192.168.0.215", if the printer name is "LBP-Printer", and if the file name is "sample.jpg">
The settings which can be used for Direct Print
The settings specified using the printer's control panel become effective. You can use the following [Setup] menus.
051R-068
