» Useful Printing Functions » Printing without the Printer Driver (Direct Print)
The direct print function is a function that transmits a file from the host terminal to the printer without the printer driver and allows the printer to detect the file and print. Therefore, you do not need to open a file to print.
Direct Print from the Remote UI
You can specify PDF, TIFF, JPEG, PS, EPS, or XPS format image files from the remote UI and perform Direct Print. For details on operating the Remote UI, see "Remote UI."
<Direct Print using Command Prompt>
You can Direct Print using the LPR command line.
When printing image files using the direct print function
Note the following when printing image files using the direct print function.
JPEG data is in compliance with the specifications of ITU-T recommendation T.81. TIFF data is in compliance with the specifications of Adobe TIFF Revision 6.0.
The supporting status of encoding methods for JPEG data is as follows.
Supported encoding method
DCT baseline
Unsupported encoding methods
DCT extension
Reversible compression
Hierarchical
The supporting status of encoding methods for TIFF data is as follows.
Supported encoding methods
Uncompressed
ITU-T recommendation T.4 One-dimensional coding
ITU-T recommendation T.4 Two-dimensional coding
ITU-T recommendation T.6 Basic facsimile coding
ITU-T recommendation T.81 JPEG (Basic DCT only)
PackBits (Apple Macintosh PackBits)
LZW
ITU-T recommendation T.82 JBIG
ITU-T recommendation T.43 JBIG
ITU-T recommendation T.44 MRC
If you cannot print a file using the direct print function or if the printing position is skewed
The file may be printed properly by opening it from an application and using the printer driver.
051R-063
