Table description
Bold values in the table indicate the default settings.
Setting Item
Setting Value
Setting
[Job Timeout]
0 to 3600 seconds
If the time specified in this item has elapsed since a job process was started, the printer automatically finishes the job and receives the next job.
If you do not want to specify the timeout, specify "0 seconds."
[Print PS Errors]
[Off], [On]
Specifies whether an error page should be printed when a PostScript error is occurring.
[Halftones]
[Text]: [Resolution], [Gradation], [High Resolution]
[Graphics]: [Resolution], [Gradation], [High Resolution] [Image]: [Resolution], [Gradation], [High Resolution] |
You can select the halftone display method from
[Resolution], [Gradation] and [High Resolution]. [Resolution] allows you to perform printing that combines smooth gradation with edge quality. It is suitable for printing graphics or graphs that use gradation.
[Gradation] allows you to print with a sharp gradation and well-balanced texture, contrasting light and shade, which is best suited for printing photo images.
[High Resolution] allows you to print in fine detail so that the edges of text data can be seen clearly. It is suitable for printing data containing text and fine lines.
[Grayscale Conversion]
[sRGB], [NTSC], [Uniform RGB]
Select the method for converting color print data to grayscale for printing.
When it is set to [sRGB], it calculates the grayscale value using the sRGB standard color conversion method.
When it is set to [NTSC], it calculates the grayscale value using the NTSC standard color conversion method.
When it is set to [Uniform RGB], it takes the average value of the Red, Green and Blue color values as the grayscale value.
[Dot Gain Adjustment]
[-10%], [-5%], [Standard],
[+5%], [+10%] |
You can adjust dotted areas to change darkness and lightness of painted areas. A higher number specifies a darker printed area.
