» Managing the Printer » Setting Items » [Setup] Menu ([Imaging] Options)
Table description
Bold values in the table indicate the default settings.
The setting items or setting values with "*" may not be displayed depending on the availability of the optional accessories and other settings.
Setting Item
Setting Value
Setting
[Image Orientation]
[Auto], [Vertical], [Horizontal]
Specifies whether the printer should print an image in portrait (vertical) orientation or in landscape (horizontal) orientation.
[Zoom]
[Off], [Auto]
Specifies whether the printer should print with scaling outputs according to the printable area.
[Print Position]
[Auto], [Center], [Top Left]
Specifies the printing position for an image.
[Print Guarantee]*
[Off], [On]
Set the processing method for received TIFF data.
When it is set to [Off], the processing time is shortened by processing received TIFF data sequentially.
When it is set to [On], it is possible to prevent errors from occurring, since all the TIFF data is received before processing begins. However, the printing speed will drop.
After specifying, perform a hard reset or restart the printer to enable the settings.
[Show Warnings]
[Off], [Print], [Panel]
Specifies the display setting for the error message in case of an error occurring.
[Print E-Mail Text]
[Off], [On]
Set e-mail print.
[Limit E-Mail Print]
[Off], [On]
[Enlarge Print Area]
[Off], [On]
Specifies whether the printer should print a document with its printable area expanded.
[Halftones]
[Resolution], [Gradation], [High Resolution]
Specify the halftone display method when printing.
When it is set to [Resolution], you can perform printing that combines smooth gradation with edge quality. It is suitable for printing graphics or graphs that use gradation.
When it is set to [Gradation], you can print with a sharp gradation and well-balanced texture, contrasting light and shade, which is best suited for printing photo images.
When it is set to [High Resolution], you can print in fine detail so that the edges of text data can be seen clearly. It is suitable for printing data containing text and fine lines.
[Grayscale Conversion]
[sRGB], [NTSC], [Uniform RGB]
Select the method for converting color print data to grayscale for printing.
When it is set to [sRGB], it calculates the grayscale value using the sRGB standard color conversion method.
When it is set to [NTSC], it calculates the grayscale value using the NTSC standard color conversion method.
When it is set to [Uniform RGB], it takes the average value of the Red, Green and Blue color values as the grayscale value.
051R-0AJ
