Item
Setting Description
Default
Setting |
Can be set in
Remote UI |
Device Information
Delivery Available |
[Output Report]
[TX/RX User Data List]
Yes, No
Yes
No
[Common Settings]
[Register Favorite Settings]
Checking Settings,
Location to Register Button: M1 to M18
No
Yes
Show Comments: On, Off
Off
No
No
Name, Comment
No
Yes
[Edit Favorite Settings]
Delete, Check Content, Rename (Name, Comment): M1 to M18
No
Yes
Off
No
No
[Display Confirmation for Favorite Settings]
On, Off
On
No
No
[Default Screen]
Standard, One-Touch, Favorite Settings, Address Book
Standard
No
No
[Change Default Settings]
Register, Initialize
No
No
[Register Options Shortcuts]
Shortcut 1: Each mode, Unassigned
2-Sided Original*1
No
No
Shortcut 2: Each mode, Unassigned
Different Size Originals*1
No
No
[TX Report]
For Error Only, On, Off
For Error Only
Yes
Yes
Report with TX Image: On, Off
On
Yes
Yes
Report with Color TX Image: On, Off
Off
Yes
Yes
[Communication Management Report]
Auto Print (100 Transmissions): On, Off
On
Yes
Yes
Specify Print Time: On, Off
Off
Yes
Yes
Timer Setting: 00:00 to 23:59
00:00
Yes
Yes
Separate TX/RX: On, Off
Off
Yes
Yes
[TX Terminal ID]
TX Terminal ID: Print, Do Not Print
Print
Yes
Yes
Print Position: Inside, Outside
Outside
Yes
Yes
Display Destination Unit Name: On, Off
On
Yes
Yes
[Delete Failed TX Jobs]
On, Off
On
Yes
Yes
[Retry Times]
0 to 5 times
3 times
Yes
Yes
[Data Compression Ratio]
High Ratio, Normal, Low Ratio
Normal
Yes
Yes
[YCbCr TX Gamma Value]
Gamma 1.0, Gamma 1.4, Gamma 1.8, Gamma 2.2
Gamma 1.8
Yes
Yes
[Use Divided Chunk Send for WebDAV TX]
On, Off
On
Yes
Yes
[Confirm SSL Certificate for WebDAV TX]
On, Off
Off
Yes
No
Add Items to Verify
CN: On, Off |
Off
Yes
No
[Limit New Destination]
E-Mail: On, Off
Off
Yes
Yes
I-Fax: On, Off
Off
Yes
Yes
File: On, Off
Off
Yes
Yes
[Always Add Device Signature to Send]*1
On, Off
Off
Yes
Yes
Restrict File Formats: On, Off
On
Yes
Yes
[E-Mail/I-Fax Settings]
[Register Unit Name]
Register Unit Name
(NULL)
Yes
No
[Communication Settings]
SMTP RX: On, Off
Off
Yes
Yes
POP: On, Off
On
Yes
Yes
SMTP Server (Server name or IP address)
(NULL)
Yes
No
E-Mail Address
(NULL)
Yes
No
POP Server (Server name or IP address)
(NULL)
Yes
No
POP Login Name
(NULL)
Yes
No
POP Password
(NULL)
Yes
No
POP Interval
0 min (Off), 1 to 99 mins
0 mins
Yes
No
[Authent./ Encryption]
POP AUTH Method: Standard, APOP, POP AUTH
Standard
Yes
Yes
POP Authentication Before Send: On, Off
Off
Yes
No
Allow SSL (POP): On, Off
Off
Yes
No
SMTP Authentication (SMTP AUTH): On, Off
Off
Yes
No
User Name
(NULL)
Yes
No
Password
(NULL)
Yes
No
Allow SSL (SMTPReceive): Always SSL, On, Off
Off
Yes
No
Allow SSL (SMTP Send): On, Off
Off
Yes
No
Display Auth. Screen When Send: On, Off
Off
Yes
No
[Confirm SSL Certificate for SMTP TX]
On, Off
Off
Yes
No
Add Items to Verify
CN: On, Off |
Off
Yes
No
[Confirm SSL Certificate for POP RX]
On, Off
Off
Yes
No
Add Items to Verify
CN: On, Off
Off
Yes
No
[Maximum Data Size for Sending]
0 (Off), 1 to 99 MB
3 MB
Yes
Yes
[Default Subject]
Default Subject
Yes
Yes
[Full Mode TX Timeout]
1 to 99 hr.
24 hr.
Yes
Yes
[Print MDN/DSN upon Receipt]
On, Off
Off
Yes
Yes
[Use Send via Server]
On, Off
Off
Yes
Yes
[Allow MDN Not via Server]
On, Off
On
Yes
Yes
[Restrict TX Destination Domain]
Restrict Sending to Domains: On, Off
Off
Yes
Yes
Permitted Domains: Register, Details/ Edit, Delete
Yes
Yes*2
[Auto Complete for Entering E-Mail Addresses]
On, Off
On
No
Yes
*1
Indicates items that appear only when the appropriate optional products are available for use.
*2
Indicates item that is not delivered as device information.
