Gamma Value for YCbCr Send Jobs
If you are sending an original in color or grayscale, you can specify the gamma value to use when converting scanned RGB image data to YCbCr. You can ensure sent image data can be printed with the appropriate image quality by setting a gamma value corresponding to the gamma value at the receiving end. You can reproduce the image with the optimal image quality at the receiving end by setting an appropriate gamma value when sending image data.
Press
(Settings/Registration).
Press [Function Settings] → [Send] → [Common Settings].
Press [YCbCr TX Gamma Value].
4.
Select a gamma value → press [OK].
This setting is disabled for the following file formats:
PDF (Compact)
XPS (Compact)
PDF (Trace & Smooth)
This setting is disabled when sending to a mail box.
