e-ManualTopSite mapHelp
Category Top
Overview of This Function
Overview of Login Services
Login Screens
SSO-H (Single Sign-On H)
Login Screens
System Requirements
Before Logging In to SSO-H
Logging In to SMS
Logging Out from SMS
Managing Applications
Uninstalling Applications
Managing Application Licenses
Installing Applications
Login Service Selection
Uninstalling a Login Service
Confirming System Information
Confirming Application Data
Confirming License Files
Changing the Password
Managing Application Logs
Logging In to SSO-H
Menu for Administrators
Registering/Editing User Data for LDAP Server Authentication
Setting the SSO-H
Setting Password Restrictions
Setting the Lockout Function
Menu for General Users
SDL Format
NetSpot Accountant 3.x Format
NetSpot Accountant 4.x Format
Troubleshooting
Other Trouble
Top » MEAP » Menu for Administrators » Setting the Security for SSO-H » Setting Password Restrictions
0L3X-23F
In SSO-H, you can prevent the simplification of passwords by setting the length, expiration period, and complexity of the password. Preventing the simplification of passwords enables increased security.
Setting the Password Length
You can set the minimum number of characters required when registering a password.
Setting the Password Expiration Period
You can set a password expiration period to ask users to change a password periodically.
Setting the Password Complexity
You can restrict the characters that can be used for passwords.
Click [Security Settings].
Specify the password restrictions.
Select [Set the password length] → set the minimum number of characters.
The minimum number of characters you can set is '1'. When a password length is set, a user cannot be registered with a blank password.
You must enter between 1 and 32 characters for the password.
Select [Set password expiration] → enter the expiration period.
You must enter between 1 and 180 days for the password expiration period.
Select [Set password complexity] → select the password complexity requirements to set.
Click [Update].
Password restriction settings are valid for passwords that are registered/edited after the restrictions are set. When a password that is already registered exceeds the restrictions, a screen prompting to change the password is displayed when user authentication is performed.
