Registering/Editing User Data for LDAP Server Authentication
Registering User Data
When the LDAP Server Authentication System of SSO-H is being used, login authentication is performed by users that belong to the LDAP server specified as the login destination. Contact the LDAP server administrator to register/edit user data for LDAP Server Authentication.
Registering Server Authentication Administrator
Make a registered user on the LDAP server a Server Authentication administrator. Specify the user attribute on the LDAP server to match the settings you specified in [Administrator Settings] in [Configuration] for SSO-H. (See "Setting the User Group to Register the Server Administrator.")
Examples:
Set "Administrators" for the "group" attribute of a user to be registered as a Server Administrator, if you specify settings in [Administrator Settings] on the [Configuration] screen as follows:
Search Criteria:
Exact Match
User Attribute:
group
Character String:
Administrators
» MEAP » Menu for Administrators » Setting the User Information for SSO-H » Registering/Editing User Data for LDAP Server Authentication
0L3X-234
