Data
References
Mail Box Settings
Fax Inbox Settings
Memory RX Inbox Settings
Mail Box/Fax Inbox/Memory RX Inbox files*1
Form for Superimpose Image
You cannot use the Import All function, depending on the recipient's machine model. For more information, contact your local authorized Canon dealer.
Data
References
Settings/Registration Basic Information
Paper Type Management Settings
Forwarding Settings
Box Settings
Department ID Management Settings
Main Menu Settings
Web Access Settings
Favorite Settings
Address Book
Quick Menu Settings
MEAP Application Setting Information
User Setting Information
Data
References
Address Lists
Device Settings (Forwarding Settings, Address Book, Send Function Favorite Settings)
Printer Settings
Paper Information
Web Access Favorites
Data
References
Quick Menu Information
Data Relating to MEAP
License files for MEAP applications
Data saved from MEAP applications*1
Instruction manuals for each MEAP application
User authentication information registered for the Local Device Authentication system of SSO-H (Single Sign-On H)
By using the HDD Data Encryption & Mirroring Kit, you can store the same data on two hard disks connected to the machine and synchronize them. Even in this case, we recommend that you regularly back up/export your important data, as it is possible that a malfunction in both hard disks may cause the data to be lost.
The passwords and PIN are backed up at the same time. However, some of the passwords may not be backed up, depending on the type of the password.
If your machine is not connected to a network, it is recommended that you print and store important information such as the Address Book. (See "Printing Reports.")
