In case C, the Import All function may not be enabled, depending on the model of the destination machine for importing. For more information, contact your local authorized Canon dealer.
If you perform the Import All function in the following cases, setting values may not be imported or may be changed into similar values.
The required optional equipment is not attached or function related to the setting information is unavailable.
The importing setting value is not valid in the destination machine for importing.
Setting Information
Case A
Case B
Case C
Preferences
Paper Settings
Paper Settings
Envelope
Paper Size Group for Auto Recog. in Drawer
A5R/STMTR Paper Selection
B5/EXEC Paper Selection
Multi-Purpose Tray Defaults
Register Custom Size
Display Settings
Default Screen after Startup/Restoration
Default Screen (Status Monitor/Cancel)
Copy Screen Display Settings
Display Fax Function
Store Location Display Settings
Switch Language/Keyboard On/Off
Use Keyboard Shift Lock Feature
Display Remaining Paper Message
No. of Copies/Job Duration Status
Notify to Clean Original Scanning Area
Change Display of Paper List Screen
Paper Type Selection Screen Priority
Change Default Display for Paper Type List
Switch Millimeter/Inch Entry
ID/User Name Display On/Off
Display Remaining Toner Error Message
Setting Information
Case A
Case B
Case C
Preferences
Timer/Energy Settings
Date/Time Settings
Time Format
Quick Startup Settings for Main Power
Auto Reset Time
Restrict Auto Reset Time
Function After Auto Reset
Auto Sleep Time
Sleep Mode Energy Use
Auto Sleep Weekly Timer
Time Settings for Auto Adjust Gradation
Energy Saver/Sleep Mode Exit Time Settings
Mode After Energy Saver Key Pressed
Change Energy Saver Mode
Low Power Mode Time
Perfect Binder Energy Saver Mode Time
End the Perfect Binder Energy Saver Mode
Setting Information
Case A
Case B
Case C
Preferences
Network
Confirm Network Connection Set. Changes
TCP/IP Settings
IPv4 Settings
Use IPv4
IP Address Settings
IP Address
Subnet Mask
Gateway Address
DHCP
RARP
BOOTP
DHCP Option Settings
IPv6 Settings
Use IPv6
Stateless Address Settings
Manual Address Settings
Use DHCPv6
DNS Settings
DNS Server Address Settings
DNS Host/Domain Name Settings
DNS Dynamic Update Settings
WINS Settings
LPD Print Settings
RAW Print Settings
SNTP Settings
FTP Print Settings
WSD Settings
Use FTP PASV Mode
Multicast Discovery Settings
Use HTTP
Proxy Settings
NetWare Settings
AppleTalk Settings
SMB Server Settings
SNMP Settings
Dedicated Port Settings
Use Spool Function
Waiting Time for Connection at Startup
Ethernet Driver Settings
Firewall Settings
Setting Information
Case A
Case B
Case C
Preferences
External Interface
USB Settings
Accessibility
Key Repetition Settings
Reversed Display (Color)
Adjustment/Maintenance
Adjust Image Quality
Correct Density
Full Color Printing Vividness Settings
Fine Adjust Zoom
Color Balance
Low Temperature Environment Mode
Correct Uneven Gloss
Adjust Drum Temperature
Special Smoothing
Gradation Adjustment During Printing
Adjust Action
Speed/Precision Priority for Double Staple
Fine Adjust Perfect Binding Finishing Size
Adjust Perfect Binding Glue Application
Color/B&W Priority for First Print Time
Alignment Adjustment When Stapling
Finisher Tray A Alignment Adjustment
Finisher Tray B Alignment Adjustment
Maintenance
Fixing Belt Auto Refresh Level
Setting Information
Case A
Case B
Case C
Function Settings
Common
Paper Feed Settings
Paper Drawer Auto Selection On/Off
Suspended Job Timeout
Paper Output Settings
Output Tray Settings
Specify Max No. of Sheets to Load in Stacker
Auto Eject Paper on Stacker Tray at Job End
High Volume Stack Mode
Offset Jobs
Job Separator Between Jobs
Job Separator Between Copies
Job Separator After Remov. Stacker Ppr. Jam
Different Paper Sizes for Output Tray
Align Output Paper of Diff. Sizes (Diff. Width)
Unprocessed Tab Paper Forced Output
Print Settings
Print Priority
Heavy 5/Heavy 6 Paper Productivity Priority
Coated Paper Productivity/Gloss Priority
Prod./Img. Qlty. Priority for Mixed Ppr. Type
Output Report Default Settings
Superimpose Image Quality Priority
Register Characters for Page No./Watermark
Copy Set Numbering Option Settings
Mixed 1-Sided/2-Sided Print Order Control
Scan Settings
Timing to Raise Feeder Tray
Feeder Jam Recovery Method
Scanner Noise Settings
Streak Prevention
B&W Scan Speed/Image Quality Priority
LTRR/STMT Original Selection
Remote Scan Gamma Value
Auto Online
Auto Offline
Generate File
Image Quality Level for Ltd. Color/Compact
PDF (Limited Color) Resolution Settings
OCR (Text Searchable) Settings
Trace & Smooth Settings
OOXML Settings
Include Background Images in Word File
Specify Minimum PDF Version
Format PDF to PDF/A
Optimize PDF for Web
256-bit AES Settings for Encrypted PDF
Rights Management Server Settings
Register Finishing Size
Set Authentication Method
Setting Information
Case A
Case B
Case C
Function Settings
Copy
Auto Collate
Image Orientation Priority
Auto Recognize Original Orientation
Select Color Settings for Copy
Send
Common Settings
Display Confirmation for Favorite Settings
Default Screen
TX Report
Communication Management Report
TX Terminal ID
Delete Failed TX Jobs
Retry Times
Data Compression Ratio
YCbCr TX Gamma Value
Allow Non-ASCII Characters for FTP Sending
Use Divided Chunk Send for WebDAV TX
Confirm SSL Certificate for WebDAV TX
Limit New Destination
Always Add Device Signature to Send
Limit E-Mail to Send to Myself
Restrict File TX to Personal Folder
Personal Folder Specification Method
Restrict Resending from Log
E-Mail/I-Fax Settings
Register Unit Name
Communication Settings
SMTP RX
POP
SMTP Server
E-Mail Address
POP Server
POP Login Name
POP Password
POP Interval
Authent./Encryption
Confirm SSL Certificate for SMTP TX
Confirm SSL Certificate for POP RX
Maximum Data Size for Sending
Default Subject
Specify Authentication User Dest. to Reply
Set Authentication User Dest. to Sender
Allow Unregistered Users to Send E-Mail
Full Mode TX Timeout
Print MDN/DSN upon Receipt
Use Send via Server
Allow MDN Not via Server
Restrict TX Destination Domain
Auto Complete for Entering E-Mail Addresses
Fax Settings
Default Screen
Register Sender Name (TTI)
Use Auth. User Name as Sender Name
Fax TX Report
Fax Activity Report
PIN Code Access
Confirm Entered Fax Number
Confirm Before Sending When Fax Dest. Incl.
Restrict Seq. Broadcast When Fax Dest. Incl.
Remote Fax TX Settings
Receive/Forward
Common Settings
Print on Both Sides
Select Drawer
Reduce Fax RX Size
2 on 1 Log
Print RX Page Footer
YCbCr RX Gamma Value
Interrupt and Print RX Jobs
Handle Files with Forwarding Errors
Set Fax/I-Fax Inbox
Use I-Fax Memory Lock
Memory Lock Start Time
Memory Lock End Time
Divided Data RX Timeout
Always Send Notice for RX Errors
Store/Access Files
Common Settings
Limit Box PIN to 7 Digits/Restrict Access
Mail Box Settings
Box Security Settings
Memory Media Settings
Secure Print
Simple Authentication Settings
Only Allow Encrypted Print Jobs
Hold
Use Hold Function
Store PS/PDF Data to Hold
Setting Information
Case A
Case B
Case C
Set Destination
Change Default Display of Address Book
Address Book PIN
Manage Address Book Access Numbers
Include Pswd. When Exporting Address Book
Register LDAP Server
Auto Search When Using LDAP Server
Register/Edit LDAP Search Conditions
Change Default LDAP Search Conditions
Acquire Remote Address Book
Make Remote Add. Book Open
Setting Information
Case A
Case B
Case C
Management Settings
Device Management
Device Information Settings
Device Information Distribution Settings
Register Destinations
Set Auto Distribution
Set MEAP Authentication
Restrict Receiving Device Information
Restrict Receiving for Each Function
Set Paper Information
Use MEAP Auth. When Receive
Communication Log
Report Settings
Display Job Status Before Authentication
Display Job Log
Save Audit Log
Store Key Operation Log
Format Encryption Method to FIPS 140-2
License/Other
Remote UI
Access by General User
Access PIN
Message Board/Support Link
Remote Operation Settings
Use ACCESS MANAGEMENT SYSTEM
Data Management
Back Up/Restore Settings
Backup Location Settings
Auto Backup Settings
HDD Data Complete Deletion
Setting Information
Case A
Case B
Case C
Settings/Reg.Shortcut
Setting Information
Case A
Case B
Case C
Function Settings
Receive/Forward
Common Settings
Set Fax/I-Fax Inbox
Set/Register Confidential Fax Inboxes
Memory RX Inbox PIN
Store/Access Files
Mail Box Settings
Set/Register Mail Boxes
Setting Information
Case A
Case B
Case C
Management Settings
User Management
System Manager Information Settings
Department ID Management
Register PIN
Setting Information
Case A
Case B
Case C
Main Menu Settings
Setting File
Setting Information
Case A
Case B
Case C
Function Settings
Copy
Register/Edit Favorite Settings
Change Default Settings
Register Options Shortcuts (Regular Copy)
Register Options Shortcuts (Express Copy)
Send
Common Settings
Register Favorite Settings
Fax Settings
Store/Access Files
Common Settings
Scan and Store Settings
Access Stored Files Settings
Copy Basic Features Screen
Color Balance (Options)
Access Stored Files
Mail Box (Print)
Setting Information
Case A
Case B
Case C
Set Destination
Rename Address List
Register One-Touch
Setting Information
Case A
Case B
Case C
Function Settings
Receive/Forward
Common Settings
Forwarding Settings
Setting Information
Case A
Case B
Case C
Quick Menu Settings
Button File
Setting Information
Case A
Case B
Case C
MEAP User Setting Information
Data
MEAP Application Setting Information
Data
Setting Information
Case A
Case B
Case C
Preferences
Paper Settings
Paper Type Management Settings
Custom Type*1
*2 |
*2 |
Setting Information
Case A
Case B
Case C
Web Access Settings*
Favorites
Settings
