      0WR6-0WF
      <Adjust Action>
      This section describes the copy and print finishing settings, such as adjusting the saddle stitch position.
      Item
      Description
      <Saddle Stitch Staple Repositioning>
      You can reposition the stapler of the saddle stitcher unit after clearing a staple jam, or after replacing the staple cartridge. Saddle stitch staple repositioning works by feeding several sheets of paper into the saddle stitcher unit and stapling them together.
      IMPORTANT:
      Only use 13" x 19", 12 5/8" x 17 11/16", 12" x 18", A3, B4, A4R, 11" x 17", LGL, or LTRR paper for the saddle stitch staple repositioning procedure.
      Make sure to remove all output booklets from the booklet tray before performing the saddle stitch staple repositioning procedure.
      Make sure to remove the paper that was used for adjustment.
      NOTE:
      Paper that is required for the saddle stitch staple repositioning procedure is automatically fed to the saddle stitcher unit by the machine.
      DeviceAdmin: Yes
      NetworkAdmin: Yes
      Can be set in the Remote UI: No
      Device Information Distribution Available: No
      <Change Fold/Stitch Position>
      If you are using the Saddle Stitch mode of the Booklet Finisher, and you notice that the saddle stitch position of the paper is not exactly in the middle of the booklet, you can make adjustments to the saddle stitch position to compensate for this error. Adjusting the Saddle Stitch Position
      IMPORTANT:
      If you want to adjust both the stitch position and the fold placement, adjust the stitch position first, and then adjust the fold placement. To adjust the fold position, see Adjusting the Saddle Stitch Folding Position.
      If both the stitch position and the fold placement are in the center of the paper after adjusting the stitch position, the adjustment of the fold placement is not necessary.
      Setting Value
      When the Booklet Finisher-W1 PRO or Booklet Finisher-X1 is attached
      <Change Fold/Stitch Position>: <Custom Size>, <13x19>, <12x18, 12_5/8x17_11/16>, <A3, 11x17>, <B4, LGL>, <A4R, LTRR>
      -2.00 mm to 0.00 mm to +2.00 mm, in 0.25 mm increments
      When the Booklet Finisher-V1 is attached
      <Change Fold/Stitch Position>: <Custom Size>, <12x18>, <A3, 11x17>, <B4, LGL>, <A4R, LTRR>
      DeviceAdmin: Yes
      NetworkAdmin: Yes
      <Adjust Saddle Stitch Fold Position>
      If you are using the Saddle Stitch mode of the Booklet Finisher, and you notice that the folds of the paper are not exactly in the middle of the booklet, you can make adjustments to the saddle stitch fold placement to compensate for this error. This mode enables you to adjust the folding position without changing the stapling position. Adjusting the Saddle Stitch Folding Position
      IMPORTANT:
      If you want to adjust both the stitch position and the fold placement, adjust the stitch position first, and then adjust the fold placement. To adjust the stitch position, see Adjusting the Saddle Stitch Position.
      Setting Value
      DeviceAdmin: Yes
      NetworkAdmin: Yes
      <Adjust Double Staple Width>
      You can adjust the double staple width.
      Setting Value
      When the Staple Finisher-W1 PRO or Booklet Finisher-W1 PRO is attached
      4 3/4" to 5 7/8"
      When the Staple Finisher-X1 or Booklet Finisher-X1 is attached
      <4_3/4">, <5_11/16">
      NOTE:
      When the paper width is smaller than 10 1/8" (257 mm), double staple width is fixed <4_3/4">.
      DeviceAdmin: Yes
      NetworkAdmin: Yes
      <Switch Finisher Puncher Mode>
      You can set whether to give priority to the punching speed or to precision.
      Setting Value
      <Speed Priority>, <Precision Priority>
      DeviceAdmin: Yes
      NetworkAdmin: Yes
      <Speed/Precision Priority for Double Staple>
      You can set whether to give priority to the double stapling speed or to precision.
      IMPORTANT:
      This mode is enabled only when using the following paper:
      Paper size: The width for the feeding direction is 8 1/2" (215.9 mm) or less
      Paper type: Plain, Heavy 1, Color, Pre-punched
      Paper weight: 17 lb bond to 32 lb bond (64 g/m2 to 128 g/m2)
      If you select <Speed Priority>, stapled output paper may not be aligned due to the temperature, humidity, or characteristics of the paper type.
      Setting Value
      DeviceAdmin: Yes
      NetworkAdmin: Yes
      <Adjust Trim Width>
      You can adjust the trimming width of Saddle Stitch printouts in 0.01" increments. When using the optional Booklet Trimmer-D1, also see the included instruction manual for more information.
      Setting Value
      0.08" to 0.78", in 0.01" increments
      DeviceAdmin: Yes
      NetworkAdmin: Yes
      You can adjust the folding positions of the paper when a folding mode such as C-fold or Z-fold is set.
      <Alignment Adjustment When Stapling>
      The copied or printed paper may shrink because of temperature, humidity, or a characteristic of the paper type. In this case, this mode enables you to align copied or printed papers by adjusting the position of the alignment guide inside the finisher so as to staple the aligned papers.
      Setting Value
      -3.0 mm to 0.00 mm to +3.0 mm, in 0.1 mm increments
      NOTE:
      If the alignment guide's position is too close to the paper, a paper jam or paper crease may occur. Make sure to perform fine adjustment of the alignment guide's position.
      DeviceAdmin: Yes
      NetworkAdmin: Yes
      <Finisher Tray A Alignment Adjustment>
      You can adjust paper alignment when outputting to Tray A of a finisher. Adjusting Paper Alignment
      IMPORTANT:
      You cannot align output paper in the following situations:
      when using paper smaller than STMTR
      when using different size paper together
      If you set <Align Output Paper of Diff. Sizes (Diff. Widths)> to <On>, you can align output paper by paper width.
      Setting Value
      NOTE:
      You can switch between positive and negative values by pressing <±>.
      DeviceAdmin: Yes
      NetworkAdmin: Yes
      <Finisher Tray B Alignment Adjustment>
      You can adjust paper alignment when outputting to Tray B of a finisher. Adjusting Paper Alignment
      IMPORTANT:
      Setting Value
      -3.0 mm to 0.0 mm to +3.0 mm, in 0.1 mm increments
      NOTE:
      DeviceAdmin: Yes
      NetworkAdmin: Yes
      <Finisher Output Priority Settings (Heavy 1-4)>
      You can give priority to productivity or alignment for the output paper when using <Heavy 1>, <Heavy 2>, <Heavy 3>, or <Heavy 4>.
      Setting Value
      <Productivity Priority>, <Alignment Priority>
      DeviceAdmin: Yes
      NetworkAdmin: Yes
      <Finisher Output Priority Settings (Heavy 5, 6)>
      You can give priority to productivity or alignment for the output paper when using <Heavy 5> or <Heavy 6>.
      Setting Value
      DeviceAdmin: Yes
      NetworkAdmin: Yes
      <Finisher Output Priority Settings (Thin)>
      You can give priority to productivity or alignment for the output paper when using thin paper.
      Setting Value
      <Precision Priority>, <Alignment Priority>
      NOTE:
      <Alignment Priority> is available only when outputting on Tray B of a finisher.
      DeviceAdmin: Yes
      NetworkAdmin: Yes
      <Time Until Stapling Starts in Stapler Mode>
      You can set the time to start stapling after the paper is inserted in the slit when you use manual stapling. For more information about manual stapling, see Optional Equipment.
      Setting Value
      1 to 3 to 5 seconds
      DeviceAdmin: Yes
      NetworkAdmin: Yes
