      0WR6-0LR
      Adjusting Paper Alignment
      You can adjust the paper alignment when outputting paper to the finisher tray if you are using the optional Staple Finisher-W1 PRO/Booklet Finisher-W1 PRO.
      1
      Press   <Adjustment/Maintenance>  <Adjust Action>  <Finisher Tray A Alignment Adjustment> or <Finisher Tray B Alignment Adjustment>.
      If you want to adjust the paper output position when using staples, select <Alignment Adjustment When Stapling>.
      2
      Adjust the paper output position.
      3
      Press <OK>.
