      0WR6-0WH
      <Adjust Fold Position>
      You can adjust the folding positions of the paper when a folding mode such as C-fold or Z-fold is set. Paper Folding Unit-J1
      Item
      Description
      <Adjust Z-Fold Position>
      You can adjust the Z-fold position.
      Setting Value
      -2.0 mm to 0.0 mm to +1.5 mm, in 0.5 mm increments
      DeviceAdmin: Yes
      NetworkAdmin: Yes
      Can be set in the Remote UI: No
      Device Information Distribution Available: No
      <Adjust C-Fold Position>
      You can adjust the C-fold position.
      Setting Value
      -7.0 mm to -1.0 mm to +5.0 mm, in 0.5 mm increments
      DeviceAdmin: Yes
      NetworkAdmin: Yes
      <Adjust Accordion Z-Fold Position>
      You can adjust the Accordion Z-Fold position.
      Setting Value
      DeviceAdmin: Yes
      NetworkAdmin: Yes
      <Adjust Double Parallel Fold Position>
      You can adjust the Double Parallel Fold position.
      Setting Value
      <A>: -2.0 mm to -1.0 mm to +5.0 mm, in 0.5 mm increments
      <B>: 0.0 mm to 1.0 mm to +5.0 mm, in 0.5 mm increments
      DeviceAdmin: Yes
      NetworkAdmin: Yes
      <Adjust Half Fold Position>
      You can adjust the Half Fold position.
      Setting Value
      -2.0 mm to 0.0 mm to +2.0 mm, in 0.5 mm increments
      <Adjust Saddle Fold Position>
      You can adjust the saddle fold position.
      Setting Value
      When the Booklet Finisher-W1 PRO is attached
      <Adjust Saddle Fold Position>: <Custom Size>, <13x19>, <12x18, 12_5/8x17_11/16>, <A3, 11x17>, <B4, LGL>, <A4R, LTRR>
      -8.50mm to 0.0 mm to +8.50mm, in 0.25 mm increments
      When the Booklet Finisher-X1 is attached
      -2.00 mm to 0.0 mm to +2.00 mm, in 0.25 mm increments
      When the Booklet Finisher-V1 is attadhed
      <Adjust Saddle Fold Position>: <Custom Size>, <12x18>, <A3, 11x17>, <B4, LGL>, <A4R, LTRR>
      DeviceAdmin: Yes
      NetworkAdmin: Yes
