      0WR6-0UF
      Staple Finisher-V1/Booklet Finisher-V1/2/3 Hole Puncher Unit-A1
      Install "Staple Finisher-V1" or "Booklet Finisher-V1" to use the following finish functions.
      Collate
      The printouts are collated into sets arranged in page order of the document.
      Group
      All printouts of the same original page are grouped together into sets.
      Offset
      Each printout group is shifted in alternating layers.
      Staple + Collate
      The printouts are collated into sets arranged in page order and stapled (Corner/Double). You can fold and staple the printouts by using "Booklet Finisher-V1."
      Staple + Group
      All printouts of the same original page are grouped together into sets and stapled (Corner/Double).
      Staple Free
      The printouts are crimped and bound without using a staple. You can easily split the paper by pressing the crimped part with your fingers. This function is useful for saving staples and also binding printouts briefly.
      For information on the paper sizes that can be used for Staple Free, see Specifications.
      Depending on the usage environment and paper type, the crimped part likely to be split.
      Manual Stapling
      You can manually staple printed paper by inserting paper in the slit. As an example of use, you can remove staples bound to the document, copy or scan it, and then staple the document again.
      Saddle Fold (Booklet Finisher-V1 only)
      The printouts are folded into half its size. Up to three sheets together can be folded.
      TIPS
      If you install the "2/3 Hole Puncher Unit-A1" in "Staple Finisher-V1" or "Booklet Finisher-V1," you can punch holes in your printouts.
      External View
      Booklet Finisher-V1
      Staple Finisher-V1
      Tray B
      The prints are output to this tray. You can specify functions for which the tray is used by configuring <Output Tray Settings>. <Paper Output Settings>
      Tray A
      Staple Button
      Press this button when you manually staple paper (Manual Stapling). You can also staple paper without pressing the button. You can specify the time period for the paper to be stapled after inserting the paper. <Adjust Action>  <Time Until Stapling Starts in Stapler Mode>
      Front cover (upper) (Booklet Finisher-V1/Staple Finisher-V1)
      Open to remove jammed paper, clear a staple jam in the stapler unit, or replace the staple cartridge. If the "2/3 Hole Puncher Unit-A1" is installed, open to discard punch waste.
      Slit
      Insert paper to manually staple the paper. You can specify the time period for the paper to be stapled after inserting the paper.
      Front cover (lower) (Booklet Finisher-V1)
      Open to remove jammed paper, clear a staple jam, or replace the staple cartridge in the saddle stitcher unit.
      Booklet tray (Booklet Finisher-V1 only)
      The printouts that are saddle stitched are output to this tray.
      Tray C
      Internal View
      Booklet Finisher-V1
      Staple Finisher-V1
      Saddle stitcher unit (Booklet Finisher-V1 only)
      Pull out to remove jammed paper or clear a staple jam in the saddle stitcher unit, or to replace the staple cartridge.
      Punch waste tray (2/3 Hole Puncher Unit-A1)
      For information on the paper sizes that can be used for Staple, Saddle Stitch, Hole Punch, and Saddle Fold, see Specifications.
      To replace the staple cartridge of the stapler unit or saddle stitcher unit, see Replacing the Staple Cartridge.
      For how to clear a paper jam or a staple jam, see Clearing Paper Jams   Clearing Staple Jams.
      Collate and group
      If you select <Offset> in combination with the collate or group function, each printout group is shifted.
      The output trays move downward as the output paper stacks accumulate. Once an output tray has reached its stacking limit, subsequent prints are automatically delivered to the next available tray. If all of the available trays have reached their stacking limits, printing stops. Remove all of the output paper from the trays to resume printing.
      Staplers
      When you are using the Staple mode, do not remove the stack of paper from the output tray during the job. Remove the stack of paper when the job has been completed.
      If the <Load staples into the stapler unit.> message appears, almost all of the staples have been used. To proceed, replace the staple cartridge.
      If a tray reaches the lowest position limit, printing stops temporarily. Remove all of the output paper from the tray to resume printing.
      Saddle stitch
      The accuracy of folds may vary depending on the paper type and the number of sheets.
