      0WR6-0L3
      Discarding Punch Waste (Staple Finisher-V1/Booklet Finisher-V1)
      Follow the procedure described in this section to discard punch waste from the 2/3 Hole Puncher Unit-A1 that is installed in the optional Staple Finisher-V1/Booklet Finisher-V1.
      1
      Open the front cover of the finisher.
      2
      Pull out the punch waste tray.
      Hold the punch waste tray handle and gently pull it toward you.
      Pull it out completely, supporting it with your hand.
      3
      Discard the punch waste.
      4
      Return the punch waste tray to its original position.
      Make sure to insert the punch waste tray as far as it will go.
      5
      Close the front cover of the finisher.
