      0WR6-028
      Loading Tab Paper
      This section describes how to load tab paper in the paper drawer using the tab feeding attachment.
      Tab paper can also be loaded in the multi-purpose tray and the optional POD Deck Lite-C1.
      Tab Paper Type
      There are two kinds of tab paper: right order tab paper and reverse order tab paper.
      Right order tab paper
      Reverse order tab paper
      When you load tab paper into the paper drawer, load reverse order tab paper face down with the tabs on the left side.
      Loading Tab Paper
      1
      Hold the handle of the paper drawer and pull it out until it stops.
      2
      Adjust the position of the paper guides.
      While pressing the top part of the left guide, slide it to the left edge.
      3
      Remove the tab feeding attachment.
      Slide the tab feeding attachment to the left.
      4
      Attach the tab feeding attachment aligning the mark for tab paper.
      Place the tab feeding attachment so that it is aligned with the mark for tab paper.
      Slide the tab feeding attachment to the back of the paper drawer.
      5
      Load the tab paper.
      Load the tab paper with the tabs on the left side.
      IMPORTANT:
      Do not exceed the load limit line when loading paper
      Make sure that the paper stack does not exceed the load limit line (). Loading too much paper can cause paper jams.
      6
      While pressing the top part of the front guide, slide it until it is aligned with the tab paper.
      7
      Gently insert the paper drawer into the machine.
      8
      Specify the paper size and type.
      For details about how to specify the paper size and type, see Specifying Paper Size and Type in the Paper Deck/Drawer. If you do not change the settings, the machine cannot print properly.
