      0WR6-02A
      Specifying Paper Size and Type in the Paper Deck/Drawer
      1
      Load the paper in the paper deck/drawer. Loading Paper in the Paper Deck/Drawer
      2
      Press .
      3
      Press <Preferences>  <Paper Settings>  <Paper Settings>.
      4
      Check the paper size that is displayed.
      When loading standard size paper, the paper size is automatically detected.
       (paper deck 1, on the right),  (paper deck2, on the left),  (top paper drawer),  (bottom paper drawer).
      Depending on the options installed, the display differs.
      NOTE:
      If the displayed paper size is different from the loaded paper size, the paper may not be loaded properly. Load the paper again.
      If <Custom> is displayed even though the standard size paper is loaded, press <Custom Size>  <Cancel Settings>. The correct size will be displayed.
      When loading custom size paper
      5
      Select the paper source in which paper is loaded and press <Set>.
      6
      Select the paper type and press <OK>.
      NOTE:
      If the paper type loaded is not displayed, press <Detailed Settings> to select from a list.
      7
      Press <OK>.
