With this method, users log in by entering their user name and password using the keyboard displayed on the control panel. This method is available regardless of the authentication device that is used.
This method uses an IC card for user authentication. To log in, users simply touch an IC card to the reader, eliminating the need to remember a user name and password. Optional equipment is required in order to use this function. For more information, contact your local authorized Canon dealer.
Check the basic configuration.
Is the machine properly connected to the computer? Setting up the Network Environment
If you are using an authentication server, have the DNS settings been configured for the machine?
If you are using an authentication server, have the date and time been properly set? Setting the Date/Time
Check the login service.
Log in to the Remote UI with Administrator privileges, click [Settings/Registration]
[User Management] [Authentication Management] [Authentication Service Information], and check that the login service is indicated as User Authentication. |
Configure the authentication server settings.
Register user information on the local device and specify the authentication server.
Select the user authentication system.
Make sure to log out after you finish using the Remote UI. If you close the Remote UI without logging out, it may take a long time to log in next time.
If you want to limit authentication method to User Authentication (restrict use of System Manager ID for authentication) when the machine is accessed from a device management software or driver, make sure to set <Prohibit Authentication Using Department ID and PIN> to <On>. <Authentication Function Settings>
