      0WR7-0K6
      <Authentication Function Settings>
      You can specify settings for user authentication that uses Department IDs and passwords and configure settings to lock out users after unsuccessful login attempts.
      Item
      Description
      <Prohibit Authentication Using Department ID and PIN>
      Select whether to prohibit authentication with a Department ID and password when operating from the printer/scanner/fax driver. If <On> is selected, authentication with System Manager ID and password is also prohibited when operating from a device management software.
      IMPORTANT:
      Jobs that are restricted by this setting are forcibly canceled on the machine.
      Setting Value
      <On>, <Off>
      DeviceAdmin: No
      NetworkAdmin: No
      Can be set in the Remote UI: Yes
      Device Information Distribution Available: No
      <Lockout Settings>
      Select whether to block users from logging in for a specified period of time after a certain number of consecutive invalid login attempts. This setting does not apply to authentication with a Department ID or PIN, or authentication for the Mail Box.
      Setting Value
      <Enable Lockout>: <On> (→), <Off>
      <On>
      <Lockout Threshold>: <(1-10)> times
      <Lockout Period>: <(1-60)> minutes
      NOTE:
      Users may be blocked from logging in before a specified number of consecutive invalid login attempts if login operations are performed on Windows or other operating systems, or from applications that use FTP, IPP, SNMPv3, SMB, or WebDAV.
      DeviceAdmin: No
      NetworkAdmin: No
