To perform personal authentication management, you must first register user information in the database of the machine.
[Authentication Management].
[OK].
[User Name] / [Password] / [Confirm]
[PIN:] / [Confirm:]
[Displayed As:]
[E-Mail Address]
[Department ID]
[Select Role to Set]|
[Administrator]
Allows access to all machine operations.
[GeneralUser]
Allows general user privileges.
[DeviceAdmin]
Allows operations that are available to general users, along with the ability to change settings related to basic functions such as copying, printing, sending, and receiving.
[NetworkAdmin]
Allows operations that are available to general users, along with the ability to change network-related settings.
[ID to Register for IC Card 1] / [ID to Register for IC Card 2] / [Verification Value]
[Set expiration for the user account]
[Disable the user account]
[User Group Association]|
Configuring settings via the control panel
You can also register user information by pressing
<Management Settings> <User Management> <Authentication Management> <Register/Edit Authentication User>. <Authentication Management>Creating user groups
Address Lists in the Address Book can be shared between users who are registered in a user group (Registering Destinations via the Remote UI). To create a user group, click [User Group Management]
[Add Group (Local Device Users)] or [Add Group (Other Users)] and perform the necessary operations on the screen that is displayed. |
TIPS
Save time by importing user information from another machine
If you click [Export] or [Import] in step 4, you can save (export) user information from the machine to a computer, or load (import) user information from another machine. This convenient procedure enables you to register user information just one time.
Check for unregistered Department IDs
If you click [Check Unregistered Department ID] on the screen displayed in step 4, you can find out Department IDs that are not registered in the machine by checking Department IDs assigned to the users against Department IDs registered in the machine.
