![](./images/book_images/pubnumbers/003_02_flk33_en_US/b_C01075_irr_ART.gif)
This mode enables you to perform OCR (optical character recognition) to extract data that can be recognized as text from the scanned image and create a PDF/XPS/OOXML (pptx/docx) file that is searchable. You can also set <Compact> if you select PDF or XPS as the file format.
For information on the optional products required to use this function, see System Options
1
Select <PDF> or <XPS>
1
Select <OOXML>
![]() ![]() ![]() To change a language to use for OCR, press <Change>
![]() ![]() Select a language or language group according to the language used in the scanned documents.
1
Select <OOXML>
Long strip originals (25 1/4" (432 mm) or longer) cannot be used with <OCR (Text Searchable)>.
If you select <PDF (OCR)>, <XPS (OCR)>, or <OOXML (OCR)> as the file format, and <Smart Scan> is set to <On> in <OCR (Text Searchable) Settings>, the orientation of the original is detected, and the document is automatically rotated if necessary before it is sent. <OCR (Text Searchable) Settings>
If you select <OCR (Text Searchable)>, you can only send at a zoom ratio of <Direct (100%)> or <Auto>.
If you select <PDF> or <XPS> as the file format, you can set <Compact> and <OCR (Text Searchable)> at the same time. In that case, <PDF (Compact)> or <XPS (Compact)> is displayed as the file format on the Scan and Send Basic Features screen.
If you select <Word> for <OOXML>, you can set to delete the scanned background images. You can generate Word files which are easy to edit without unwanted images. <Include Background Images in Word File>
Item
Details
Language Settings for Character Recognition
For PDF/XPS/PowerPoint files:
Characters are recognized based on the language you select in <Switch Language/Keyboard> (<Switch Language/Keyboard>).*1 For Word files:
Characters are recognized based on the language you select after pressing <Change> when you create a Word file. |
Recognizable Asian Languages
Japanese, Chinese (Simplified), Chinese (Traditional), Korean
Recognizable Character Types and Fonts (Asian Languages) |
Recognizable European Languages and Language Groups
Languages:
English, French, Italian, German, Spanish, Dutch, Portuguese, Albanian, Catalan, Danish, Finnish, Icelandic, Norwegian, Swedish, Croatian, Czech, Hungarian, Polish, Slovak, Estonian, Latvian, Lithuanian, Russian, Greek, Turkish Language Groups:
Western European (ISO)*2, Central European (ISO)*3, Baltic (ISO)*4 Recognizable Character Types and Fonts (European Languages) |
Item
Details
Japanese:
Alphanumeric characters, Kana characters, Kanji characters (JIS first level, and some of the JIS second level), Symbols Chinese (Simplified):
Alphanumeric characters, Chinese characters, Symbols (GB2312-80) Chinese (Traditional):
Alphanumeric characters, Chinese characters, Symbols (Big5) Korean:
Alphanumeric characters, Chinese characters, Hangul characters, Symbols (KSC5601) |
Recognizable Fonts
Multiple fonts are supported. (Ming-cho type is recommended.)
Italicized characters cannot be recognized.
Fonts Used for Converted Characters (Only when Word is selected as the file format)
Japanese:
Asian characters: MS Mincho European characters: Century Chinese (Simplified):
Asian characters: SimSun European characters: Calibri Chinese (Traditional):
Asian characters: PMingLiU European characters: Calibri |
Item
Details
Alphanumeric characters, Special characters of the recognized language*1, Symbols
Recognizable Fonts
Multiple fonts are supported. (Times, Century, and Arial are recommended.)
Italicized characters can be recognized.
Calibri
Italic style is not reproduced.
Item
Details
Original Format
Printed documents, Word processor documents (documents consisting of text, graphics, photographs, or tables, and with no character slant)
Text Format
Horizontal and vertical writing (documents containing both horizontal and vertical writing can also be recognized)
Only horizontal writing can be recognized for European languages and Korean text.
One to three column documents with no complex column settings
Character Size
8 to 40 point
Table Format (For Word Format Only)
Tables that meet the following conditions:
Tables consist of squares divided with solid lines
Tables with up to 32 columns
Tables with up to 32 rows
Some originals suitable for OCR processing may not be processed properly.High accuracy may not be achieved with originals including a large amount of text on each page.
Characters may be replaced with unintended characters or be missing due to the background color of the original, form and size of characters, or slanted characters.*
Paragraphs, line breaks, or tables may not be reproduced.*
Some parts of illustrations, photographs, or seal impressions may be recognized as characters and be replaced with characters.*
* When Word is selected as the file format.
