Fax Basic Features Screen
Pressing <Fax> on the Main Menu displays the Fax Basic Features screen.
Destination
Displays the destination's name, the fax number, and the number of destinations you specified.
<De- tails>
Enables you to check the detailed information of the destination displayed in
![](./images/book_images/b_in_C0000_01.gif)
<Delete Dest.>
Enables you to delete the destination displayed in
<Tone>
If you press this button when specifying the destination, the character "T" (tone) is inserted. Even if you are using pulse dial, numbers following "T" will be sent using tone dial. Press this button when using fax information services.
One-touch button
Enables you to specify a fax destination registered in one-touch buttons.
<Address Book>
Enables you to specify a fax destination registered in the Address Book.
<On-Hook>
Press to send a fax document manually.
Sending Faxes Manually (Manual Sending)
<Direct Send>
Press to check the connection to the recipient's fax machine before scanning originals.
Checking the Connection to the Recipient Before Sending (Direct Send)
![](./images/book_images/b_in_C0000_09.gif)
![](./images/book_images/pubnumbers/003_02_flk33_en_US/b_in_btn_C0003_31.gif)
Press to register destinations in one-touch buttons.
Registering a Destination in a One-Touch Button
<Options>
Displays all of the function setting buttons. For convenience, you can display frequently used function setting buttons in
![](./images/book_images/b_in_C0000_11.gif)
Function setting buttons
Displays the most frequently used buttons from <Options>. The setting status is displayed on the buttons. You can also press
![](./images/book_images/b_in_C0000_14.gif)
to change which buttons are displayed.
Current setting status and setting buttons
Displays setting status such as the resolution. Make sure to confirm the settings in order to scan properly. To change the settings, press the desired button.
Basic Operations for Sending Faxes
<Favorite Settings>
Register frequently used scan settings here in advance to easily recall them when necessary.
Registering a Combination of Frequently Used Functions
![](./images/book_images/pubnumbers/003_02_flk33_en_US/b_in_btn_C0003_29.gif)
Press this icon to register the current settings in <Favorite Settings> of
![](./images/book_images/b_in_C0000_13.gif)
and change the button displayed in
<Previous Settings>
<To Remote Address Book>
Press to specify destinations in one-touch buttons of other Canon multifunction printers. This button is available only when the Remote Address Book is activated for use.
<Set Destination> ![](./images/book_images/b_in_arrow_right.gif)
<Acquire Remote Address Book>
Some functions cannot be used in combination with each other. Buttons that cannot be selected are displayed in light gray.
LINKS
