Registering a Destination in a One-Touch Button
It is convenient to register a frequently used destination in a one-touch button. This enables you to quickly specify a destination with the simple press of a button. In addition to registering a fax number or e-mail address in a one-touch button, you can also register a file server folder location (IP address and path) to use when storing scanned data.
Just as with the Address Book, you can register destinations in a one-touch button from the LDAP server or combine destinations into a group (Registering a Group in a One-Touch Button).
1
Press <Dest./Fwd. Settings> on the Main Menu  <Register One-Touch>.
2
Select the one-touch number to register the destination in, and press <Register/Edit>.
A three-digit number (001 to 200) is assigned to each one-touch button. You can also specify a one-touch button by pressing  and entering the three-digit number using the numeric keys.
3
Select functions you want to register.
Select the functions to use for the destination, from <Fax>, <E-Mail>, <I-Fax>, or <File>.
4
Press <Name>  enter the destination name, and press <OK>.
5
Press <One-Touch Name>  enter the one-touch button name to be displayed, and press <OK>.
6
Configure settings depending on the functions selected in step 3.
For more information about the settings, see step 6 in Registering Destinations in the Address Book.
7
Press <OK>  <Close>.
Destinations registered in one-touch buttons can be combined into a group and registered as a single destination. You can also register a Mail Box (machine's temporary storage space) in a group (Making Simple Edits to Files).
1
2
Select the button you want to register and press <Register/Edit> <Group>.
3
Press <Name>  enter the group name, and press <OK>.
4
5
Select the destinations you want to register in a group.
If you want to select a destination from a one-touch button, press <Add from One-Touch>  select the destination  press <OK>. If you want to select a Mail Box (machine's temporary storage space), press <Store in Mail Box> select the Mail Box  press <OK>.
6
Press <OK>  <Close>.
TIPS
If the LDAP server has already been registered in the machine (Registering the LDAP Server), you can search for destinations and register them in one-touch buttons. Press <Dest./Fwd. Settings>  <Register One-Touch>  select the one-touch button you want to register  press <Register/Edit>  <LDAP Server> and search for destinations using <Search by Conditions> or <Search by Name>. After confirming the settings of the destination, press <One-Touch Name>   enter the one-touch name to be displayed  press <OK>.
If the time setting between the LDAP server and the machine differs by five minutes or more, a search cannot be performed.
Unlike the Address Book, you cannot select more than one destination at a time to register.
The destination information you can acquire through searching only includes names and e-mail addresses.
13WJ-03E
