Embedding a TL Code when copying originals enables the restriction of reproduction. It is possible to not only restrict reproduction, but also to permit reproduction only when login information and passwords are identified.
To enable Document Scan Lock using a TL Code, see Using TL Code to Restrict Copying.
<OK>.
<Close>.
Embedding a Secure WatermarkYou can embed a Secure Watermark together with TL Codes. Prior to step 9, press <Watermark Information> and specify the settings for embedding. For information on Secure Watermarks, see Embedding the "TOP SECRET" Text (Secure Watermark).
Adjusting TL Code formatsYou can adjust the settings of a TL Code such as the size on the screen in step 4. When you cannot scan the embedded information properly, adjust these settings.
Depending on the device used, the embedded information may not be scanned properly even after the TL Code adjustment. In addition, it may not be scanned properly when the original's entire surface is a photograph.
