You can enlarge an image and copy it to multiple sheets of paper to create a large poster by joining the sheets together. There are two methods for copying to multiple sheets of paper; specifying the copy ratio only, and specifying the number of sheets of paper to use.
You cannot create a poster using custom size paper, envelopes, transparencies, or tab paper.
If you set <Poster>, <Full Color> is set for <Select Color>.Basic Copy Operations
Copy Ratio and Paper SettingsThe following table indicates an estimate of the original size and copy ratio for different size posters and the optimal paper size and number of sheets to use.
Refer to this table when entering the copy ratio and when specifying the paper size and number of sheets.
You can create a poster using an original size and copy ratio not indicated in this table, but the maximum original size is 11" x 17" and the maximum copy ratio is 400%.
Since the poster is output after being divided into the optimal number of sheets, fewer sheets may be output than the number you specify.
The poster size after the copied sheets are joined will be slightly smaller than the value in the table.
TIPS
Joining the copied sheets |
The copied sheets have areas where the images overlap (
and ), as indicated in the diagram below. When joining the sheets together, cut these areas to an appropriate width and glue them together.![]()
<Next>.
<Next>.
