Making Booklets (Booklet Copying)
You can set the print layout so that the printouts turn into a booklet when they are folded in half. Using options enables you to automatically process operations such as folding in half and stapling in the crease (Saddle Stitch). Optional Equipment
Adjust booklet tray guide
For booklets, adjust the optional booklet tray guide to the paper size. Improper adjustment may result in a paper jam.
Paper
There are restrictions for paper that can be used with this function. Take note of the following. For information on restrictions on paper for each option, see Specifications.
Depending on paper size and type, booklet copying may not be available.
The number of sheets to be printed using saddle stitch is limited.
Paper that can be used for the content and cover pages is limited.
1
Place the original. Placing Originals
When copying a vertically long original, place the original in portrait orientation.
2
Press <Copy> on the Main Menu. <Main Menu> Screen
3
Press <Options> on the Copy Basic Features screen. Copy Basic Features Screen
4
Press <Booklet>.
5
Press <Booklet Scan>.
When you perform booklet copying with 2-sided originals, press <2-Sided Original> and select <Book Type> or <Calendar Type> as necessary.
When you copy an original that is already in booklet format, such as one printed from the machine using booklet copying, press <Do Not Booklet Scan>.
6
Select how to bind the booklet.
7
Set the original size and the output size.
Press <Change> in <Original Size> and select the size of original. If you select <Auto>, the booklet size is automatically selected according to the size of original.
Press <Change> in <Layout Size> and select the paper size for the booklet.
To make the booklet in the same print size as the original print size, select the output size of the facing pages. If you specify the same size in <Original Size> and <Layout Size>, the print size on the booklet is automatically reduced.
8
<Add Cover>  Specify the cover settings and press <OK>.
Select whether to copy the original onto the cover and the back cover.
Press <Change> in <Paper Size> and select the paper size of the cover and the paper source.
Make sure to use the same size paper for the cover and content pages.
If you use heavy paper for the cover, you can only print on <Front Inside Cover> and <Back Inside Cover> depending on the thickness of the paper.
9
<Opening Type>  Select the opening type and press <OK>.
10
Press <Set Details> and specify detailed settings as necessary.
When the number of pages is large
When the inner pages protrude after being folded in half
Adjusting the saddle stitch position
Adjusting the folding position of the paper
Making the booklet with square spine
11
Press <OK>  <Close>.
12
Press .
Copying starts.
13WJ-0S6
