Copying Immediately by Interrupting Other Jobs
You can copy immediately even while another operation is being performed. This is convenient for cases in which you only want to copy several pages urgently, but another person's output will not finish soon.
1
Place the original. Placing Originals
2
Press <Copy> on the Main Menu. <Main Menu> Screen
3
Press <Interrupt> on the Copy Basic Features screen. Copy Basic Features Screen
4
Specify the copy settings as necessary. Basic Copy Operations
5
Press .
The previous job is paused and interrupt copying starts.
To cancel interrupt copying, press <Interrupt> again before pressing .
When interrupt copying finishes, the previous job restarts automatically.
During interrupt copying, you cannot perform another interrupt copying. After the current interrupt copying finishes, perform the next interrupt copying.
TIPS
You can interrupt jobs with a reserved copy job (Basic Copy Operations).
To interrupt the current job and perform a reserved copy job, press   <Copy/Print>  <Job Status>  Select the document to copy  <Interrupt/Priority Print>  <Interrupt and Print>.
To perform a reserved copy job right after the current job finishes, press   <Copy/Print>  <Job Status>  Select the document to copy with the first priority  <Interrupt/Priority Print>  <Priority Print>.
13WJ-047
