You can use the Remote UI to print, send, or delete files that are stored in the Mail Box, or faxes and I-faxes that are temporarily stored in the Fax/I-Fax Inbox.
1
Select the check box for a file that you want to print, and click [Print...].
You can select multiple files.
2
Click [Start Printing].
You can click [Move to Top], [Move Up], [Move Down], or [Move to Bottom] to change the order in which files are printed.
You can click [Change Print Settings...] to change the print settings.
If you select the check box for [Delete File After Printing], files are automatically deleted after they are printed.
1
Select the check box for a file that you want to send, and click [Send...].
2
Click [Select Destination...], select the destination, and click [OK].
You can click [Move to Top], [Move Up], [Move Down], or [Move to Bottom] to change the order in which files are sent.
You can click [Settings...] in [Set Details] to change the send settings. You can also change detailed settings of the file in [File Settings]. Scanning
If you select the check box for [Delete File After Sending], files are automatically deleted after they are sent.
3
Click [OK].
1
Select the check box for all of the files that you want to merge.
2
Click [Merge Files...] and enter a file name in [File Name].
You can click [Move to Top], [Move Up], [Move Down], or [Move to Bottom] to change the order in which files are merged.
3
Click [Start].
1
Select the check box for the file that you want to insert the second file into, and click [Insert Pages...].
2
Select the file to insert, and click [Next].
3
Enter the new file name in [File Name After Insertion], and specify the insertion location (page) in [Select Insertion Location].
The file is inserted before the page specified in [Select Insertion Location].
4
Click [Insert].
1
Select the check box for a file that you want to duplicate, and click [Duplicate...].
2
Select the number of the destination Mail Box in [Target Box], and click [Start].
1
Click a [Type] icon or file name.
2
Click [Change File Name...], enter the new name in [File Name], and click [OK].
1
2
Select the check box for the pages that you want to delete, and click [Delete Page]
![]() You can also click [Delete Pages Consecutively...] and specify a range of pages to delete.
1
Select the check box for the file that you want to delete.
2
Click [Delete]
To change the settings of a Mail BoxYou can click [Settings...] on the screen displayed in step 3 to change the name and PIN for the selected Mail Box. Specifying the Mail Box Settings
1
Select the check box for a document that you want to print, and click [Print...].
You can select multiple documents.
2
Documents are automatically deleted after they are printed.
1
Select the check box for a document that you want to forward, and click [Send...].
2
Click [Select Destination], select the destination, and click [OK].
You can click [Move to Top], [Move Up], [Move Down], or [Move to Bottom] to change the order in which the files are forwarded.
If you select the check box for [Delete File After Sending], documents are automatically deleted after they are forwarded.
3
Click [OK].
1
2
Click [Delete]
To check I-faxes that were divided when receivedClick [Divided Data RX Inbox] on the screen displayed in step 2 to display a list of I-faxes that were divided when received. Receiving I-Faxes
To set a PIN for Memory RX InboxYou can change the PIN for the Memory RX Inbox by clicking [Settings...] on the screen displayed in step 3 and adding a check mark to [Set PIN].
To configure Memory Lock settingsYou can set whether to receive faxes and I-faxes in the Memory RX Inbox by clicking [Memory Lock Settings...] on the screen displayed in step 3.
1
2
If you select the check box for [Delete File After Printing], documents are automatically deleted after they are printed.
1
2
Click [Delete]
To change the settings of a Confidential Fax InboxYou can change the name and PIN for the selected Confidential Fax Inbox by clicking [Settings...] on the screen displayed in step 3.
