This function is to save in the specified storage location (Confidential Fax Inbox) the received documents that match specific conditions. The Confidential Fax Inbox contains multiple boxes, and each box can be protected by password. By specifying a condition such as saving all documents from Company A in Box No. 10, you are allowed to only check the documents you need. This function also enables you to prevent unauthorized persons from seeing confidential documents unintentionally by setting a password. When the [Processing/Data] indicator on the control panel maintains a steady green, follow the following procedures to check/print saved documents.
To use this functionSome settings such as the save location and password for documents need to be registered beforehand. <Forwarding Settings>
TIPS
You can set to receive the URL of the save location by e-mail when receiving documents. Just entering the URL in the address bar of a Web browser enables you to check the contents of documents from your computer through the Remote UI. <Set/Register Confidential Fax Inboxes>
