Correcting Uneven Density
Adjustments may not be performed effectively if there is not sufficient toner.
Correction with a Densitometer
Measure a test page you have output with a commercial densitometer and enter the measured density values to correct the density of halftone areas.
1
Press
<Adjustment/Maintenance>
<Adjust Image Quality>
<Correct Shading>
<Densitometer Correction>.
2
Press <Start Printing>.
A test page is printed.
3
Measure the test page with a densitometer.
Measure marks 1 to 7 printed on the test page, and make a note of the density values that are detected.
4
Press <Fine Adjust> for each color.
5
Enter the density values.
Enter the density values you measured and made a note of in step 3 in 1 to 7 for each color.
6
Press <OK>.
7
Press <Output Test Page>
<Start Printing>.
A test page after correction is output.
8
If there is no problem with the test page, press <Store and Finish>.
If the density of the test page after correction is uneven, perform the procedure indicated in
Visual Correction.
Visual Correction
Visually measure a test page you have output to perform correction using the density adjustment values you determine. Use this procedure when you do not have a densitometer or when correction is not effective.
1
Press
<Correct Shading>
<Visual Correction>.
2
<Start Printing>.
3
Visually check the test page to determine the density adjustment values.
Range of Marks Printed
The range of marks printed for each color may be -6 to +6 or -5 to +5, depending on the paper size used for the test page.
4
5
Enter the density values according to the results that you visually checked in step 3 from -6 to +6 (or -5 to +5) for each color.
Enter a plus value to increase the density, or a minus value to decrease the density.
6
Press <OK>.
7
<Start Printing>.
8
