TIPS
, the Status Monitor/Cancel screen is displayed, allowing you to check the toner level, the space remaining in the waste toner container, and the remaining amount of staples.
TIPS |
You can check the remaining amount of consumables from the Remote UI.
check the toner level.
<Consumables/Others>
checking the space remaining in the waste toner container.
Estimated space remaining
When <OK> is displayed, enough space remains in the container. It is not necessary to replace the waste toner container.
When <Near Full> is displayed, the space remaining in the container is running low. Prepare a new waste toner container so you can replace it at any time.
When <Full> is displayed, the waste toner container is full. Replace it with a new waste toner container.
check the remaining amount of staples.
Estimated remaining amount of staples
When <OK> is displayed, enough staples remain. You do not need to replace the staples.
When <Light> is displayed, the remaining amount of staples is small. Prepare new staples so you can replace them at any time.
When <Empty> is displayed, no staples remain. Replace them with new staples.
