Adjusting Print and Finish Quality
Adjust the settings below if printing results are not satisfactory, or if you want to adjust the paper folding position.
Gradation Adjustment
If the brightness of the printing is significantly different from the original document, this correction adjusts the printing so that it more closely matches the original document.
Color Tone Correction
If the color of the printing is significantly different from the original document, this correction adjusts the printing so that it more closely matches the original document.
Density Correction
If the density of the printing is significantly different from the original document, this correction adjusts the printing so that it more closely matches the original document.
Shading Correction
If the image areas of the printing have uneven density, this correction adjusts the printing so that the density is even. There are two methods for correcting the density; densitometer correction and visual correction.
Color Mismatch Correction
If the colors of printing run or blur, color mismatch (color misregistration) may have occurred. This correction adjusts the printing so that color mismatch does not occur.
Vividness Setting
This setting enables you to make colors more saturated when performing color printing.
Image Size Adjustment
If the size of the image copied is significantly different from the original document, fine adjustment is performed so that the printing more closely matches the size of the original document.
Dither Pattern Setting
This setting enables you to use a suitable dither pattern to make printed images smoother.
Color Adjustment
This setting enables you to perform fine adjustment to the density and strength of the color balance.
Saddle Stitch Position Adjustment
If the saddle stitch position of the paper is not exactly in the middle of the booklet, you can make adjustments to the saddle stitch position.
Saddle Stitch Folding Position Adjustment
You can adjust the saddle stitch folding position during booklet printing.
Paper Folding Position Adjustment
You can adjust the folding position of paper when setting each type of folding configuration.
