For information on the product numbers for toner cartridges, see Consumables.
You can check the current amount of toner remaining.
The "XXXX" in the message indicates the toner color.
When replacing multiple toner cartridges at the same time, replace them in the order black, yellow, magenta, cyan.
An error message is displayed if the small cover does not open automatically due to the toner replacement cover being closed, etc. Press the icon on the bottom right of the screen, and follow the instructions on the screen to perform the operation again from step 1.
If you select a color with toner remaining, a confirmation message is displayed. To cancel replacing the toner, press <No> to deselect that color.
Make sure to avoid applying shocks to the toner cartridge by hitting it against something, etc. Doing so may cause the toner to leak.
Do not have the white part of the toner cartridge face down. Doing so may prevent the toner from being supplied properly.
If printing was interrupted because toner ran out, it will automatically resume when you replace the toner cartridge.
Even if cyan, magenta, or yellow toner runs out, you can continue to print in black-and-white as long as black toner remains, but the printing quality will drop. If you want to continue printing in black-and-white, do not replace the toner cartridge until printing is complete.
If the color and density of printing differ after replacing the toner cartridge, perform adjustment.
