<Adjust Image Quality>
This section describes how to adjust image quality for copying and printing.
<Auto Adjust Gradation>
<Adjustment/Maintenance>
If the brightness of the printing is significantly different from the original document, this correction adjusts the printing so that it more closely matches the original document.
Adjusting Gradation
It is recommended that you select <Full Adjust> when performing an automatic gradation adjustment. Select <Quick Adjust> for a quick, but less complete adjustment between regular full adjustment recalibrations.
Only plain paper can be used for printing test pages with this machine. You cannot select a paper source loaded with paper other than plain.
Test pages are not counted as part of the copy or print total page counts.
<Auto Correct Color Tone>
<Auto Correct Color Tone Settings>
If the color of the printing is significantly different from the original document, this correction adjusts the printing so that it more closely matches the original document.
Adjusting Color Tone
<Register Correction Pattern>
To create an adjustment standard of your choice for color adjustment, register an adjustment standard.
<Job Type to Apply To>
Set whether to perform color adjustment for copy jobs and print jobs.
<Correct Density>
If the density of the printing is significantly different from the original document, this correction adjusts the printing so that it more closely matches the original document.
Adjusting Density
<Correct Shading>
If the image areas of the printing have uneven density, this correction adjusts the printing so that the density is even.
Correcting Uneven Density
<Auto Correct Color Mismatch>
If the colors of printing run or blur, color mismatch (color misregistration) may have occurred. This correction adjusts the printing so that color mismatch does not occur.
Correcting Color Mismatch
<Full Color Printing Vividness Settings>
This setting enables you to make colors more saturated when performing color printing.
Making Colors More Vivid
<Fine Adjust Zoom>
If the size of the image copied is significantly different from the original document, fine adjustment is performed so that the printing more closely matches the size of the original document.
Adjusting Image Size
<Dither Pattern Settings>
Set the dither pattern to change the way printed images are reproduced.
Setting the Dither Pattern
<Color Balance>
This setting enables you to perform fine adjustment to the density and strength of the color balance.
Adjusting Color Balance
