If the machine is in the Sleep mode (the touch panel is not displayed, and only
(Energy Saver) is lit), you may be unable to open the paper deck unit. In this case, press (Energy Saver) to reactivate the machine, and then press the open button on the paper deck unit.If you need to lift up the lifter (for example, if you drop objects inside the paper deck), do not lift up the lifter more than 2" (50 mm) or diagonally, as this may result in a malfunction or damage to the machine.
The Multi-drawer Paper Deck-A1 is an optional product.
The following paper sizes can be loaded into the Multi-drawer Paper Deck-A1: 13" x 19", 12" x 18", 12 5/8" x 17 11/16", 11" x 17", LGL, LTR, LTRR, STMTR, EXEC, and custom size (5 1/2" x 7 1/8" to 13" x 19 1/4" (139.7 mm x 182 mm to 330.2 mm x 487.7 mm))
CAUTION |
When handling paper, take care not to cut your hands on the edges of the paper.
The Multi-drawer Paper Deck-A1 can only accommodate paper from 14 lb bond to 110 lb cover (52 to 300 g/m2) in weight.
If paper runs out and printing is stopped when you are printing in the Staple mode, do not remove the output sheets that are waiting to be stapled. (Printing and stapling resume after you clear the paper jam.)
You can load custom size paper if both of the paper sides are between 7 1/8" (182 mm) and 19 1/4" (487.7 mm) in length, and between 5 1/2" (139.7 mm) and 13" (330.2 mm) in width. You cannot load custom size paper if either one of the sides is smaller or larger than the paper sizes that can be loaded.
If a message prompting you to load paper appears during printing, the remaining prints are automatically made after you load the correct paper. If you select a different paper source, the remaining prints are made after you press [OK].
To cancel printing, press [Cancel].
When changing the paper to load into the Multi-drawer Paper Deck-A1 from plain paper to coated paper, you may wait a moment because temperature control of the warm air which fans a paper is required.
The inside lifter automatically descends to the paper loading position.
It may take some time for the paper deck to open, even if you press the open button.
For high-quality printouts, use paper recommended by Canon.
Before loading paper, always fan the sheets several times, and align the edges to facilitate feeding.
The inside lifter automatically ascends, and the machine becomes ready for printing.
CAUTION |
When closing the paper deck, be careful not to get your fingers caught, as this may result in personal injury.
Do not subject the paper holder plate to shock when loading paper into the paper deck, as this may result in a malfunction or damage to the machine.
![]() Do not load the following types of paper into the Multi-drawer Paper Deck-A1. Doing so may cause a paper jam.
Severely curled or wrinkled paper
Thin straw paper
Paper which has been printed on using a thermal transfer printer
The reverse side of paper which has been printed on using a thermal transfer printer
Heavy paper (more than 158 lb index (300 g/m2))
Thin paper (less than 14 lb bond (52 g/m2))
Tracing paper
Envelopes
Paper which is curled must be straightened out before loading it into the paper deck.
Never place paper or any other items in the empty part of the paper deck next to the paper stack. Doing so may damage the machine.
You will not be able to make copies or print if you load paper that exceeds the loading limit mark (
), or if the paper deck is not completely pushed into the machine.Make sure that the height of the paper stack does not exceed the loading limit mark (
).Always check that the paper deck is in place.
When loading paper into the paper deck for the first time, adjust the size change plate to match the paper size being loaded. (See "Changing the Paper Size for the Multi-drawer Paper Deck-A1.")
When loading paper into the paper deck, make sure that the paper size setting is the same size of the paper that is being loaded.
Load the paper below the rollers of the paper holder.
![]() When loading paper, make sure that the height of the paper stack does not exceed 13/16" (20 mm). If the height of the paper stack exceeds 13/16" (20 mm), the edges of the paper stack may become curled or creased, and poor print quality may result.
For instructions on loading tab paper into the paper deck, see "Loading Tab Paper."
For instructions on loading transparencies, see "Loading Transparencies."
If there are instructions on the paper package about which side of the paper to load, follow those instructions.
When paper is loaded in the Multi-drawer Paper Deck-A1, the side facing up is the one printed on.
If problems, such as poor print quality or paper jams occur, try turning the paper stack over and reloading it. However, textured paper, single-sided coated paper, and paper already printed on cannot be turned over. Change to new paper.
For more information on the print direction of preprinted paper (paper which has logos or patterns already printed on it), see "Relationship Between the Original Orientation and Paper Orientation."
Rewrap any remaining paper in its original package, and store it in a dry place, away from direct sunlight.
If paper runs out and printing is stopped, load a new paper stack. Printing restarts after the new paper stack is loaded.
CAUTION |
CAUTION |
When returning the paper deck to its original position, be careful not to get your fingers caught, as this may result in personal injury.
![]() Adjust the outer size change plate, inner size change plate, and paper holder plate correctly to avoid causing a paper jam, dirty prints, or making the inside of the machine dirty.
If you use a paper which length of the parallel edge to the feeding direction is shorter than 18" (457.2 mm), load the paper below the loading limit of the paper holder plate.
![]() If there are instructions on the package of paper about which side of the paper to load, follow those instructions.
When paper is loaded into the Multi-drawer Paper Deck-A1, the side facing up is the one printed on.
If problems occur, such as poor print quality or paper jams, try turning the paper stack over, and reload it. However, textured paper, single-sided coated paper, and paper already printed on cannot be turned over. Change to new paper.
