Top » Before You Start Using This Machine » Backing Up/Exporting Data
08JK-004
Various data such as the received data, stored data, address book, and Settings/Registration settings are stored on the hard disk of the machine.
A malfunction in the hard disk may cause these data to be lost. Please regularly back up/export your important data.
Please note that Canon will not be held responsible for any damages caused by the loss of data.
You can backup/export data in the following ways:
Backup/Restore
Import/Export All
Import/Export Individually
You can backup/export the following data:
Data You Can Backup/Restore
You can backup data in the machine and restore the data to the machine. The backed up data can only be restored to this machine.
Data
References
Mail Box Settings
Fax Inbox Settings
Memory RX Inbox Settings
Attribute information for Advanced Box documents
Mail Box/Fax Inbox/Memory RX Inbox files*1
Advanced Box files*2
Form for Superimpose Image
*1 You can also backup/restore data in another machine of the same model.
*2 You can also backup/restore data in another machine of the imageRUNNER ADVANCE series.
Data You Can Import/Export All
You can save/load multiple items at once. In addition, you can exchange data with this machine and other machines which support the Import/Export All function.
You cannot use the Import All function, depending on the recipient's machine model. For more information, contact your local authorized Canon dealer.
Data
References
Settings/Registration Basic Information
Paper Type Management Settings
Forwarding Settings
Box Settings
Department ID Management Settings
Main Menu Settings
Web Access Settings
Favorite Settings
Address Book
User Access Control for Advanced Box
Quick Menu Settings
MEAP Application Setting Information
User Setting Information
Data You Can Import/Export Individually
You can save/load data individually. In addition, you can exchange data with this machine and other machines which do not support the Import/Export All function.
Data
References
Address Lists
Device Settings (Forwarding Settings, Address Book, Send Function Favorite Settings)
Printer Settings
Paper Information
Web Access Favorites
Other Data You Can Import/Export
You can exchange data with this machine and other machines which do not support the Import/Export All function.
Data
References
Quick Menu Information
User information of the Advanced Box
Data Relating to MEAP
License files for MEAP applications
Data saved from MEAP applications*1
Instruction manuals for each MEAP application
User authentication information registered for the Local Device Authentication system of SSO-H (Single Sign-On H)
*1 You may be able to back up data stored by MEAP applications, depending on the application.
By using the HDD Data Encryption & Mirroring Kit, you can store the same data on two hard disks connected to the machine and synchronize them. Even in this case, we recommend that you regularly back up/export your important data, as it is possible that a malfunction in both hard disks may cause the data to be lost.
The passwords and PIN are backed up at the same time. However, some of the passwords may not be backed up, depending on the type of the password.
If your machine is not connected to a network, it is recommended that you print and store important information such as the Address Book. (See "Printing Reports.")
