Managing Application Licenses
You can add, disable, or delete license files for installed applications.
Once you have deleted the disabled license file, you cannot download it from the machine.
Disabling a license file must be performed after stopping the application you want to disable. You cannot disable a license file if the application has not been stopped.
When a disabled license file is generated, the status of that license file becomes <Uninstalled> and the application becomes unusable.
You can increase counter values and extend terms of validity by adding a license file.
Click [MEAP Application Management].
Click the name of the application to add a license file for.
Click [License Management].
4.
Click [Browse…].
5.
In the dialog box that appears, select the license file that you want to install → click [OK].
6.
Click [Install].
The message <Installing... Please wait.> appears.
7.
Click [Yes].
Installation will start after the message <Installing... Please wait.> appears again.
If the license of an application is expired or disabled, it is necessary to restart (stop and start) the application after the new license file is added.
You must disable a license file before deleting or downloading it.
Click the name of the application to disable the license file for.
4.
Click [Disable].
5.
Click [Yes].
Downloading/Deleting Disabled License Files
If you want to uninstall an application, you must first delete the license file. Also, if you want to back up before deleting, download and store the license file on your computer.
Click the name of the application to download or delete the license file for.
To download the license file:
Select [Download].
Follow the instructions on the screen and specify the location to store the file.
To delete the license file:
Select [Delete].
Click [Yes].
The downloaded or disabled license file can be reinstalled to the same machine.
Only disabled license files can be downloaded or deleted.
If you want to delete a license file, depending on the license file, you may need to download the file after disabling it.
