Before using this function, it is useful to read the following topics:
Main Power and Control Power (See "Main Power and Control Panel Power.")
Entering Characters from the Touch Panel Display (See "Entering Characters from the Touch Panel Display.")
Routine Maintenance (See "Maintenance.")
If you are using a login service, log in and out of the service before and after operating the machine.
If you are using Department ID Management with the Copy Card Reader-F1, see "Copy Card Reader-F1."
If you are using Department ID Management, see "Entering the Department ID and PIN."
If you are performing user authentication using the SSO-H login service, see "Login Service."
To check whether the file was stored correctly in the Advanced Box/the Advanced Box of another machine on the network, press
