<Memory Media> in [Store Location Display Settings] is set to 'Off' by default. To use memory media, set <Memory Media> to 'On'. (See "Store Location Display Settings.")
It is necessary to set <Use MEAP Driver for External USB Device> to 'Off' to use memory media. (See "Using the MEAP Driver for USB External Storage.")
Insert the USB memory straight into the USB port. If you insert it at an angle, or insert USB memory that does not meet the USB specifications, the USB port may be damaged.
If
does not appear, re-insert the memory media. |
If the USB Device Port-D1 and Multimedia Reader/Writer-A2 are installed, you can use SD cards, Memory Sticks, CF cards, and Microdrives as memory media. For more information, see "USB Device Port-D1" and "Multimedia Reader/Writer-A2."
to scroll through the stored files.|
You can cancel a selection by selecting the document again.
If there are two or more files stored in the memory media, you can press [Name] or [Date/Time] to sort the list of files.
If you close the File Selection screen after sorting the files, the files will be unsorted the next time you open the File Selection screen.
If you press [Name], or [Date/Time] with a file selected, that file is unselected, and the top of the file list appears.
For more information on paper types, see "Available Paper Stock."
(numeric keys).|
If multiple files are selected, you can change the number of prints by pressing [Change No. of Copies].
To cancel printing, press [Stop]. (You cannot cancel printing by pressing
(Stop).)To reserve the next print job, press [Close] → follow the procedure to reserve a print job. (See "Reserving Jobs.")
You can select and print up to six files in the same memory media at a time. However, you cannot select files with different file formats at the same time.
You can only select multiple files when the files are stored in the same folder.
To cancel all settings, press [Back to Default Set.].
