Category
Top » MEAP » System Requirements » SSO-H (Single Sign-On H)
Category Top
Overview of This Function
Overview of Login Services
Login Screens
Login Screens
System Requirements
Before Logging In to SSO-H
Logging In to SMS
Logging Out from SMS
Managing Applications
Uninstalling Applications
Managing Application Licenses
Installing Applications
Login Service Selection
Uninstalling a Login Service
Confirming System Information
Confirming Application Data
Confirming License Files
Changing the Password
Managing Application Logs
Logging In to SSO-H
Menu for Administrators
Registering/Editing User Data for Domain Authentication
Setting the SSO-H
Setting the User Group to Register the Domain Administrator
Setting Password Restrictions
Setting the Lockout Function
Menu for General Users
SDL Format
NetSpot Accountant 3.x Format
NetSpot Accountant 4.x Format
Troubleshooting
Trouble That May Occur When Using SSO-H
Other Trouble
Collapse all|Expand all
SSO-H operates with the system environment described in "Domain Authentication" and "Local Device Authentication."
To use Domain Authentication, you must match the current time on the server in which Active Directory is running with the machine (and the computer to log in with).
When using Domain Authentication, make sure you register a Domain Authentication administrator. If you do not register a Domain Authentication administrator, some settings and management functions may not be available, depending on the application. The registration method differs depending on your system environment.
The user that belongs to the "Canon Peripheral Admins" group on Active Directory is the administrator for Domain Authentication. Follow the instructions in the manual for Active Directory to create the "Canon Peripheral Admins" group, and then register a Domain Authentication administrator.
If the default password is being used, the screen for changing the password is automatically displayed for security purposes. Change the password. (See "Registering/Editing User Data for Local Device Authentication.")
A windows server in which Active Directory is installed and a DNS server for name resolution are necessary to use Domain Authentication.
Windows Server to Install Active Directory (Domain Controller)
Software
Operating system:
Windows Server 2003 SP2
Windows Server 2003 R2 SP2
Windows Server 2008 SP2
Windows Server 2008 R2
This version of SSO-H is compatible with both 128-bit AES (Advanced Encryption Standard) and DES (Data Encryption Standard) as the Kerberos encryption type to be used when performing Domain Authentication. The encryption type automatically switches according to the Active Directory settings. AES is used in an environment that supports both encryption types.
If you use Windows Server 2003 SP2/R2 SP2 for the Active Directory, only the IPv4 communication protocol is supported (IPv6 cannot be used).
System Requirements for Domain Authentication Administrators and General Users
Operating System
Web Browser
Java Runtime Environment
Windows XP Professional SP3
Internet Explorer 7
Java Runtime Environment 1.5 or later
Windows Vista SP2
Internet Explorer 8
Windows 7
Internet Explorer 8
Internet Explorer 7
Internet Explorer 8
Mac OS X v 10.3
Safari 1.3.2
Java 2 Platform Standard Edition 5.0
Mac OS X v 10.4
Safari 2.0.4
Mac OS X v 10.5
Safari 3.1.2
Mac OS X v 10.6
Safari 4.0.3
System Requirements for Domain Authentication Administrators and General Users (When Using IPv6 Communications)
Operating System
Web Browser
Internet Explorer 7
Windows Vista SP2
Internet Explorer 8
Windows 7
Internet Explorer 8
Internet Explorer 7
Internet Explorer 8
Other System Requirements
Access privileges to Windows 2003/2008 Domain Name System (DNS)
Access privileges to Domain Controller
Server Ports Used
The following server ports are used when using Domain Authentication with SSO-H:
Port Number
Application
53
Communication with the DNS server
88
Domain Authentication with the KDC (Key Distribution Center)
389
LDAP communications with the directory service (Default is 389, but it can be changed to a user-defined port in the LDAP service properties.)
An Active Directory environment network is not necessary to use Local Device Authentication.
System Requirements for Local Device Authentication Administrators and General Users
Operating System
Web Browser
Internet Explorer 7
Windows Vista SP2
Internet Explorer 8
Windows 7
Internet Explorer 8
Internet Explorer 7
Internet Explorer 8
Mac OS X v 10.3
Safari 1.3.2
Mac OS X v 10.4
Safari 2.0.4
Mac OS X v 10.5
Safari 3.1.2
Mac OS X v 10.6
Safari 4.0.3
System Requirements for Local Device Authentication Administrators and General Users (When Using IPv6 Communications)
Operating System
Web Browser
Internet Explorer 7
Windows Vista SP2
Internet Explorer 8
Windows 7
Internet Explorer 8
Internet Explorer 7
Internet Explorer 8
For information on obtaining the Java Runtime Environment or Java 2 Platform Standard Edition, see the Oracle Web site.
You must use the user logon name (pre-Windows 2000) registered in Active Directory in order to enter a user name for Domain Authentication.
You can use only alphanumeric characters for Domain Authentication. You cannot use symbols (\ / : * ? l <> [ ] ; , = + . "), or spaces. You can log in only if you use valid characters.
User names and passwords are registered in a database in the machine.
When using the Local Device Authentication system, you can use only alphanumeric characters for the user name.
Port number is a default value. If you change the settings, the port number is different. (See "Before Logging In to SSO-H.")
