Category
Top » MEAP » Menu for Administrators » Setting the Security for SSO-H » Setting the Lockout Function
Category Top
Overview of This Function
Overview of Login Services
Login Screens
SSO-H (Single Sign-On H)
Login Screens
System Requirements
Before Logging In to SSO-H
Logging In to SMS
Logging Out from SMS
Managing Applications
Uninstalling Applications
Managing Application Licenses
Installing Applications
Login Service Selection
Uninstalling a Login Service
Confirming System Information
Confirming Application Data
Confirming License Files
Changing the Password
Managing Application Logs
Logging In to SSO-H
Registering/Editing User Data for Domain Authentication
Setting the SSO-H
Setting the User Group to Register the Domain Administrator
Setting Password Restrictions
Menu for General Users
SDL Format
NetSpot Accountant 3.x Format
NetSpot Accountant 4.x Format
Troubleshooting
Trouble That May Occur When Using SSO-H
Other Trouble
Collapse all|Expand all
In SSO-H, you can set a lockout function that temporarily stops the login service for a user that fails user authentication. The lockout function enables increased security.
Setting the Conditions for Enabling the Lockout Function
You can enable the lockout function depending on certain conditions.
Setting the Lockout Threshold
When the lockout function is set for SSO-H, you can set the number of times after which to stop the login service for a user that fails user authentication. If a user fails the user authentication more than the set lockout threshold within three minutes, the login service is stopped. For example, if you set the lockout threshold to five times, the lockout function is enabled and the login service is stopped for the specified period of time when a user fails user authentication five times in three minutes.
Setting the Lockout Time
When the lockout function is set for SSO-H, you can set the length of time that the login service is stopped for a user.
Click [Security Settings].
Specify Lockout Settings.
Select the conditions for enabling the lockout function.
Specify the [Threshold of account lockout] setting.
You can set between 1 and 10 times for the lockout threshold.
Specify the [Lockout Time] setting.
You can set between 1 and 60 minutes for the lockout time.
Click [Update].
