If you try to access SMS without the default key set, 'HTTP 500 Internal Server Error' is displayed and login fails.
By setting the default key, SMS will always use encrypted SSL communications, regardless of whether [Use SSL] in [MEAP Settings] in [Management Settings] (Settings/Registration) is set to 'On' or 'Off'.
(Settings/Registration).|
For instructions on creating the key pair and self-signed server certificate required for SSL encrypted communication using the control panel of the machine, see "Key Pair and Server Certificate Settings for Encrypted SSL Communication" (Security).
For instructions on setting the key pair used for encrypted SSL communication, see "Setting the Key Pair Used With SSL Encrypted Communications" (Network).
