Category
Top » Optional Products/Software » Removable HDD Kit
Category Top
System Configuration
Optional Equipment
Sample System Configurations
System Options
Optional Products Required for Each Function
DADF-AG1
Platen Cover Type R
Cassette Feeding Unit-AF1
Envelope Feeder Attachment-D1
Paper Deck Unit-B2
USB Device Port-D1
Multimedia Reader/Writer-A2
Inner Finisher-D1/Inner 2/3 Hole Puncher-A1
Staple Finisher-G1/Booklet Finisher-G1/External 2/3 Hole Puncher-B2
Inner 2Way Tray-H1
Copy Card Reader-F1
ADF Access Handle
Removable HDD Kit
Setting/Removing the Hard Disk Holder
Software
imageWARE ADVANCE Desktop
imageWARE Enterprise Management Console
imageWARE Publishing Manager
imageWARE Scan Manager DS
Workflow Composer
imageWARE Document Server
Collapse all|Expand all
Removable HDD Kit
The Removable HDD Kit can hold hard disks. You can remove and store the hard disks in a safe place when the machine is not in use.
Parts and Their Functions
1
Hard Disk Holder
Holds the hard disk. To store the hard disk, place it in the hard disk holder.
2
Front Cover
Open this cover to set/remove the hard disk holder.
The Removable HDD Kit can be attached to the side of the machine. For information on attaching the Removable HDD Kit to the machine, contact your local authorized Canon dealer.
If the message <E602-0001> appears on the touch panel display when the machine starts, a hard disk may not be inserted in the Removable HDD Kit. Turn OFF the main power of the machine and check that the main power indicator on the control panel is not lit, and then check the Removable HDD Kit. If the error message still appears after you correctly set the hard disk, contact your local authorized Canon dealer.
