Category
Top » Optional Products/Software » Envelope Feeder Attachment-D1
Category Top
System Configuration
Optional Equipment
Sample System Configurations
System Options
Optional Products Required for Each Function
DADF-AG1
Platen Cover Type R
Cassette Feeding Unit-AF1
Paper Deck Unit-B2
USB Device Port-D1
Multimedia Reader/Writer-A2
Inner Finisher-D1/Inner 2/3 Hole Puncher-A1
Staple Finisher-G1/Booklet Finisher-G1/External 2/3 Hole Puncher-B2
Inner 2Way Tray-H1
Copy Card Reader-F1
ADF Access Handle
Removable HDD Kit
Setting/Removing the Hard Disk Holder
Software
imageWARE ADVANCE Desktop
imageWARE Enterprise Management Console
imageWARE Publishing Manager
imageWARE Scan Manager DS
Workflow Composer
imageWARE Document Server
Collapse all|Expand all
The following four types of envelopes can be loaded into the envelope feeder attachment:
No. 10(COM10): 4 1/8" × 9 1/2" (104.7 mm × 241.3 mm)
Monarch: 3 7/8" × 7 1/2" (98.4 mm × 190.5 mm)
DL: 4 3/8" × 8 5/8" (110 mm × 220 mm)
ISO-B5: 7" × 9 7/8" (176 mm × 250 mm)
ISO-C5: 6 3/8" × 9" (162 mm × 229 mm)
Parts and Their Functions
1
Left Guide
Use the Left Guide to align the length of the envelopes being loaded.
2
Back Width Guide
Fix the Back Width Guide in place using the provided screws to match the width of the envelopes.
3
Envelope Receptacle
The Envelope Receptacle pushes the envelopes up so that they can be fed correctly, even when there are only a few envelopes left.
4
Front Width Guide
Fix the Front Width Guide in place using the provided screws to match the width of the envelopes.
5
Size Switch
Select either '1' or '2' for the envelope type.
