e-ManualTopSite mapHelp
Top » Optional Products/Software » System Configuration » System Options
System Options
0UKW-02H
By installing system related optional accessories, the user can expand the functionality of the machine. This section describes the system related optional accessories and their functions.
For information on the optional products required to use each function, see "Optional Products Required for Each Function."
Direct Print Kit (for PDF/XPS)
The Direct Print Kit (for PDF/XPS) enables you to print PDF and XPS files from the Remote UI.
It is also necessary when printing PDF and XPS files stored in memory media, or the Advanced Box of another imageRUNNER ADVANCE series machine on the network.
Barcode Printing Kit
The Barcode Printing Kit enables you to print bar codes.
PCL International Font Set
The PCL International Font Set enables you to add the following fonts for a PCL printer. As a result, you can output using multiple languages in a SAP Unicode environment.
Andale® and WorldType® Collection J (Japanese Version)
Andale® and WorldType® Collection K (Korean Version)
Andale® and WorldType® Collection S (Simplified Chinese Version)
Andale® and WorldType® Collection T (Traditional Chinese Version)
In order to support differences in character design depending on the region, four font versions are enabled.
Document Scan Lock Kit
The Document Scan Lock Kit enables you to embed hidden user information or copy restriction information in the output when documents are printed and reduce the risk of confidential information being leaked. It helps you to restrict scanning of the document (Scan Lock function) and identify the user that output the document (Tracking function). This option enables you to embed TL code.
The Image Data Analyzer Board, which is needed to detect the scan lock information, help restrict unauthorized copying, and analyze the tracking information is included with this kit. This board enables you to analyze TL code.
The scan lock information cannot be detected with the imageRUNNER ADVANCE C350P.
Secure Watermark
The Secure Watermark mode enables you to embed hidden text in the background of copies. You can embed text, such as "CONFIDENTIAL," the date and time, or a department name. The embedded text only appears when the machine prints the copies.
HDD Data Encryption Kit
The HDD Data Encryption function enables you to reduce the risk of confidential information being leaked by encrypting all of the data stored in the hard disk of the machine.
Web Access Software
The Web Access Software enables you to view Web pages from the touch panel display of the machine.
Encrypted Secure Print Software
The Encrypted Secure Print Software enables you to encrypt print data sent from a computer using the Secure Print function, and decrypt it at the machine. This enables you to strengthen the security of print data by preventing the contents of your printed documents from being seen by other users, and preventing the unauthorized use of confidential information.
